Well here we go again...
Old May 11, 2009 | 03:58 PM
  #111
silver-mod-o's Avatar
Hunt&Fisherator
If they're original, you've got to heat the ends and melt the plastic sealer out, the just press out, press in, and install the clips. Not hard at all...
Old May 11, 2009 | 04:15 PM
  #112
nonnieselman's Avatar
Originally Posted by GMCtrk
nonnie, how hard is it to replace and put in a new U joint? Is this something anyone can do or does it have to be done by a driveshaft shop?
When i got the new center support bearing i got them to install the new Ujoints, yoke and center support. it took a 100ton press to get the center support off.. that stupid thing was on there good.
but the plastic sealer is something i tell ya..
Old May 12, 2009 | 09:42 AM
  #113
Hunt&Fisherator
Well I think the last "big piece" is on its way
Ordered a 10" Circle-D billet 3500 converter. And its going to bolt up to my existing flexplate situation. So no conversion stuff there.
Ill be chasing down the right slip yoke and U joint today so MAYBE I can start going back together with this thing sooner than later.
Also considering pulling the front clip off so I can set the motor/trans in together. Undecided.
Old May 12, 2009 | 12:27 PM
  #114
GMCtrk's Avatar
Im surprised you didn't go with the triple disk. I thought locking up the converter really helped out with turbos?
Old May 12, 2009 | 01:49 PM
  #115
Hunt&Fisherator
The way my lockup settings are in HPT, I never put much demand on a clutch. My converter locks up only in 4th gear, above 55mph and less than 50% throttle, roll into the throttle and it unlocks and you're back in the power and boost... And it will never lock on the track.
And I personally HATE how the truck feels in boost with a locked converter. I didn't feel like a multi-disk was warranted honestly given the situation.
Old May 12, 2009 | 03:40 PM
  #116
It can give you a better MPH cause it loads it more.
But can you imagine the stress it sees tryin to lock up with over 500ft/tq goin thru it?
Old May 12, 2009 | 03:43 PM
  #117
GMCtrk's Avatar
I thought you lock up the stock 80e converter on a regular basis?
Old May 12, 2009 | 03:46 PM
  #118
when i first put the 80E in, it was locking up on the stock tune.. but i changed that cause i didnt want any transmission problems. mine locks up under part throttle and in boost sometimes.. but Bens never locks up unles he is cruising.
Old May 12, 2009 | 03:50 PM
  #119
GMCtrk's Avatar
how much of a SOTP difference did you notice with it locked compared to unlocked? Reason I ask is this could influence my choice to go triple disk or not.
Old May 12, 2009 | 03:52 PM
  #120
Its been quite awhile.. ive never ran it on the track locking it up..
