Well here we go again...
Old May 4, 2009 | 10:57 PM
  #101
silver-mod-o's Avatar
Hunt&Fisherator
I wish Kurt, nothing fun going on to take pics of really... Just rebuilding the same leaf spring. Setup everyone else has LOL
Old May 10, 2009 | 01:49 PM
  #102
Hunt&Fisherator
Well the rear suspension is officially overhauled... New V6 leaf springs (removed overloads again) new shocks, new 3/4" poly bumpstops, and all new grade 8 bolts in everything.... The axle will be bolted back in today hopefully and ill be able to put wheels back on it...
These jackstands are beginning to look too "at home" under my truck...
I need to start looking around for someone to shorten and high speed balance my driveshafts... Besides shafts and a converter, my 80E conversion is all but done.
Also picked up a mildly built '03 4L80E to swap in, I may stock a fresh valve body and solenoids/shift kit in there just to be on the safe side.
Old May 10, 2009 | 07:10 PM
  #103
nonnieselman's Avatar
So when do i need to head that way???
I have a good shop over here if all else fails. Wait, why do you need to shorten the DS?
Old May 10, 2009 | 08:09 PM
  #104
brent5631's Avatar
My driveshaft fit right up with the correct yoke.
Old May 10, 2009 | 08:11 PM
  #105
mine did too
Old May 10, 2009 | 10:57 PM
  #106
GMCtrk's Avatar
Neapco N3R-3-9161X and Precision Premium #534 or Precision Super Strength #235
Or
2500HD yoke and Precision #447 U joint if you wish to use oem yoke. But end up with a bastard joint.
All that should bolt right up to an ECSB 2wd.
Old May 11, 2009 | 07:54 AM
  #107
Hunt&Fisherator
So all I need is the factory 2500HD slip yoke and conversion U joint? I don't mind the bastard U joint really, as long as I can get a few of them to stockpile. That's one less thing on my list
I haven't completely dug through the conversion write up threads to be honest and this swap is new territory for me I still plan on having my driveshafts balanced... They've been chunked out from under this thing at high rates of speed a few times since they were balanced last time
Looks like the main thing left is to order a converter and get the last of the details nailed down...
Nonnie- I may be closer now than I originally thought buddy!!!
Old May 11, 2009 | 08:00 AM
  #108
GMCtrk's Avatar
I'm doing the Neapco yoke, same one tarinitup and superado have.
Also, superado said he's seen that preceision 447 u joint break a lot
Old May 11, 2009 | 08:14 AM
  #109
awesome... now hurry up!!
I just went to the local drivetrain shop and told them i wanted the TH400 Long yoke..
went home and did some measuring with the DS bolted up and marked the yoke and i think i chopped off 5/8" of an inch.
Old May 11, 2009 | 12:10 PM
  #110
GMCtrk's Avatar
nonnie, how hard is it to replace and put in a new U joint? Is this something anyone can do or does it have to be done by a driveshaft shop?
