Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Apr 29, 2014 | 08:25 PM
  #171
lsxperformance's Avatar
Probly in t case, I chased a vibration in mine one was a growling noise, in the floor. Tore front diff apart found pits in the carrier bearings and in the pinion so I replaced them. Still had a vibration then I checked the rear axle pulled posi out of it and checked contact and back lash. That was fine, then I changed the Trans to my built 60 when I did my mods hoping it's was a planetary. Nope, then I thought I'd shake down the front end and one of the wheel hubs was rough and loose. It was the third time I checked it did it actually show up being bad. Changed it and the growling vibration is gone.... But I still have intermittent clunks and thuds in my floor board. From the **** box awd t case... Lol maybe this helps but probly won't..
Old Apr 30, 2014 | 12:23 AM
  #172
Vortec350ss's Avatar
Rob, what are your Pinion angles?
Haven't actually measured them but that's because they look so good. It's in my short list of things to check.
Originally Posted by TIM Z
This is what I asked him , I know all too well what bad angles will do :/
Yea You did... Unfortunately I haven't had time to check them yet. I really don't think it will be my problem but certainly can't rule it out without actually measuring.
I'm not getting any moaning or groaning like I have a bad bearing somewhere... But anything is possible and I appreciate all ideas.
Thanks guys.
Old Apr 30, 2014 | 12:36 AM
  #173
oakley6575's Avatar
You must have superman vision cause my blurry *** eyes can't measure angles +-1* I need an angle finder for that.
Old Apr 30, 2014 | 12:59 AM
  #174
Ya it was a tough one for me to rule out. It wouldn't make the noise when you would jack it up and free spin. When you think about it these trucks are drivetrain nightmares to diagnose. There are roller/ taper bearings all over the place and everything is magnesium/aluminum. So the slightest noises/ vibrations are magnified and conducted through the chassis.
My tcase just one day started making these awful noises. I **** you not it was soo loud I thought I dropped a driveshaft/ or sheered the roll pin in a final drive and it was slapping the pinion I had to stop and get out and look. That's what my t case sounds like when it changes the front to rear bias.. Also why I no longer care to kill it on the dyno.. Lol. Not sure what killed it to be honest truck has been babied the whole time I've had it. The only thing I can think is when I bought it I changed the fluid in t case and didn't put the blue smurf jizz back in.. Not sure if it's a common failure or not.
Old Apr 30, 2014 | 04:07 AM
  #175
TIM Z's Avatar
11 sec. Truck Mod
Rear end cover looks good bud .
Old Apr 30, 2014 | 04:16 AM
  #176
03sierraslt's Avatar
Blue smurf jizz is important for the vicious coupling.
Old Apr 30, 2014 | 06:01 AM
  #177
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
We need more videos of the corsa exhaust. For as long as youve been around here I'd think youd know atleast one rev in an exhaust video is mandatory. Im disappointed in you
Old Apr 30, 2014 | 08:53 AM
  #178
You should stick to what GM recommends in the transfer cases
Thanks Tim. I love these girdles.
What he said... your'e really begging to kill this thing, huh? lol
Ah I know... I had planned to have much more by now but I'm chasing my tail with this vibration. I'll have actual good videos of it soon.
Old Apr 30, 2014 | 09:42 AM
  #179
Rob- make the videos real soon or don't come back.
Old Apr 30, 2014 | 03:18 PM
  #180
spent21's Avatar
if you can duplicate the noise/vibration at very light to no load, then knock the transmission into neutral at the regular speed that you feel it and give the engine a few revs +/- of the rpm that you feel the vibration.
If it doesn't change with engine speed, it's drivetrain.
