TXsilverado 2.0 Build Thread
Old May 12, 2012 | 10:14 AM
  #41
TXsilverado's Avatar
except that GM already picked up the core i wanted to buy
Old May 12, 2012 | 10:41 AM
  #42
BadAssChevy327's Avatar
sweet build. with how well your extended cab did im excited to see you build a s10
Old May 15, 2012 | 02:22 PM
  #43
picked up a MSD 6012 ignition controller with map sensor and an air cleaner today. $280 shipped.
not my motor, but the air cleaner.
i traded my ruger LCP for a set of new hedman ls1 swap fox body midlength headers that my dad had laying around. i doubt they will fit the s10 but i'm sure i can sell them for a good profit and put that money towards my headers. i only had $300 into my 380 lcp so i was totally willing to trade my $300 gun for $600 headers the cam, carb and intake should be rolling in today
Old May 17, 2012 | 03:12 PM
  #44
and now there's a transmission. the plan was to use a stock 80e on a shift kit. not exactly a direct swap but it was doable. i ended up with a 60e that needs a rebuild but it has all the good hard parts in it. i will be sure to update the price when i figure out exactly how much i will have into it. it wont be anywhere near as cheap as a stock 80e, but a direct swap and should hold just fine behind the 3400lb truck.
Old May 17, 2012 | 03:22 PM
  #45
Tootall's Avatar
I have a TransGo HD2 80e shift kit with a used plate. All the springs and valves are new/never been used. The plate was drilled for full race.
$60 bucks if you're interested, or make an offer.
Old May 17, 2012 | 03:46 PM
  #46
i ended up with a 60e. no need for an 80e parts
Old May 19, 2012 | 06:03 PM
  #47
i ran into something new today. drug the motor out and decided to slip the new cam in and paint the valley and valve covers. timing chain cover comes off an i only have 1 large bolt in the cam gear. WTF? aparently this is something GM only did on the 07 and 08 ls2 engines. never heard of it before. guess i gotta find a new 3 bolt cam gear and tensioners from a 06 vette from what i'm reading.
Old May 19, 2012 | 06:09 PM
  #48
BlackGMC's Avatar
Resident Retard
Interesting. So what about the reluctor ring thing? Do you need to mess with that?
Old May 19, 2012 | 06:11 PM
  #49
skinny chicken's Avatar
I have a brand new 3 bolt gear if you want it. free to a good home.
Old May 19, 2012 | 06:46 PM
  #50
i dont think so. from what i understand, you can run a LS1 cam in a LS2, but you cannot put a LS2 cam into a LS1 based engine. someone may come in and correct me on that though.
anyone else know for sure?
