TXsilverado 2.0 Build Thread
Old Sep 6, 2012 | 09:38 AM
  #201
BlackGMC's Avatar
Resident Retard
Hmmm. What a pain. Personally i would just go with a smaller cam. I am lazy if you cant tell.
Old Sep 6, 2012 | 09:56 AM
  #202
TXsilverado's Avatar
and here i was thinking about getting a bigger cam since i'm having to flycut anyways remember...4600 converter that should flash closer to 5k on nitrous. small cam my ***
Old Sep 6, 2012 | 10:00 AM
  #203
Beau@SDPC's Avatar
Trucks Sponsor
beau, remember when i asked if you could think of anything else i may need and i said i knew i was forgetting something?
i dont have a crank or cam position sensor!
Sorry for the late reply...
I have them in stock. Check your PMs!
Old Sep 6, 2012 | 10:02 AM
  #204
07, but i may ask around to see which cam position sensor works best with the ignition controller that i have. i've heard of people having to cut and switch the cam position wires depending on which position sensor they are running.
does SDPC rent flycutting tools?
Old Sep 6, 2012 | 03:09 PM
  #205
black00chev's Avatar
Slowest turbo build ever!
Would you be able to run a thicker head gasket to help with the PTV clearance?
Old Sep 6, 2012 | 03:13 PM
  #206
unless they make a .130 thickness gasket lol. theres virtually zero P2V on the intake with a stock gasket. the motor turns fine but the dial indicator doesnt read anything.
Old Sep 6, 2012 | 03:39 PM
  #207
ouch! haha. I guess fly cutting it is then.
Old Sep 29, 2012 | 03:11 PM
  #208
made time to flycut the pistons today. .099 exhaust clearance and i cut .090 off of the intake side to get .072 intake cleearance. aside from the cam and crank sensors, the motor will be completely buttoned up tomorrow. transmission time!
Old Sep 29, 2012 | 06:13 PM
  #209
oakley6575's Avatar
Lets see some pics of the motor! When do you hope to get it in the truck?
Old Sep 30, 2012 | 12:03 PM
  #210
i havent buttoned it up yet. no clue on when i will get it into the truck. once the transmission is finished i'll start pulling the truck apart for the new power plant.
