TXsilverado 2.0 Build Thread
#702
This guy got the compressor to work in the factory location.
LS1TECH - View Single Post - S10 Xtreme L33 swap!
#703
Havent looked at the thread but im sure he just cut and boxed the frame which is easy enough. My problem is the factory ac box, fan and drier. These headers take up a lot of room in a s10
#704
it's running good again. fresh springs all the way around and it feels strong
backfires and popping is gone. more importantly that tap is gone. if it's not 1 thing it's another. from my 50mph punch, the radiator came loose from the core support. the radiator hose got a hole burnt into it by the belt. i'll replace it and get back to tuning it. I want to go to the track on Friday with a buddy of mine to see what it does running all 8.
#710
new upper hose and drove it again tonight. lean as **** at very light throttle and lean at WOT. 13.5-13.7 seems to be the avg. i'm currently 4 sizes up on the 2ndary. i'm going to go up 4 sizes on the primary and see what happens. i doubt that i will get the tune lined out enough to visit the track again. i'm still running into fuel pressure issues.
fires up perfect at 7psi, then drops to 4psi 20 minutes into a ride. question: will heat to a cable cause resistance when trying to get alternator power to the battery if the extreme heat source is between the two? my 2 gauge battery wire is about an 1.5" from a primary.
