Turbo.
Old Aug 24, 2010 | 08:34 PM
  #31
kbracing96's Avatar
^^^ Because those are $500 dollars! Even the one I built, I spent over $200 building it. That plate cost $15,
Old Aug 24, 2010 | 08:50 PM
  #32
BlackGMC's Avatar
Resident Retard
pretty welds, very nice kit!
Old Aug 24, 2010 | 08:53 PM
  #33
Daryn's Avatar
Formerly darynC-10/23/10
yeah unless you have a cnc mill. hand making that piece with tight tolerances , and more than one at that!... hmm
Old Aug 24, 2010 | 11:05 PM
  #34
2005 Silverado's Avatar
SPAM HUNTER
I see this as working flawless...and that 500 dollar valve failing at some point
Didnt get a whole lot done today.
Got to the shop and just decided to do the heater lines instead of the oil pan, i want to have all the fittings and stuff ready so i can just get the drain done in one sitting, so that will most likely be this weekend.
I have the t in the 1 line for the throttle body bypass. The v6 32" radiators dont have the nipple like the v8s. I might get a longer hose for the bypass hose so i can move the hoses a little farther from the down pipe.
The bumper on these things is way to easy to pull off. Thanks GM.
Tomorrow. I think im taking a day off from it, but if not the intercooler will be mounted and the coldside will be ran.
Old Aug 24, 2010 | 11:36 PM
  #35
Daryn's Avatar
i printed a picture of that valve out. i may see what i can do on the cnc mill this weekend
Old Aug 24, 2010 | 11:39 PM
  #36
SPAM HUNTER
all it is a plate with a boost actuated valve, shouldnt be a 500 dollar part...but it is.
Old Aug 25, 2010 | 12:30 AM
  #37
Daryn's Avatar
hardest part is keeping tight tolerances in the hinge system when going from cold to hot. cant let exhuast escape!.. prolly a bronze bushing of someshort
Old Aug 25, 2010 | 09:53 PM
  #38
SPAM HUNTER
well you make one for under 100 bucks and ill try it
Need 1 more coupler. Turbo outlet is bigger then the t70's.
Also i cant find my freaking ev6 injector pigtails i ordered 2 months ago which pisses me off!
SO all i did tonight was bolt up the intercooler.
I still cant find the fittings for my oil drain, but i hope to by this weekend.
Old Aug 25, 2010 | 10:50 PM
  #39
53RUSSELL's Avatar
I got mine from Loppers and took the fitting to a local welding shop and they weld it on for me.
Your taking about the oil pan right?
Old Aug 25, 2010 | 11:10 PM
  #40
SPAM HUNTER
why must people quote pictures.
Also im just trying to decide on what fittings i want to use.
