Turbo 07 Sierra build
Old Jun 6, 2019 | 10:04 PM
xKILLORADOx's Avatar
Default Turbo 07 NBS RCSB Sierra build
Alright everyone, here's the beginning stages of my 07 Sierra build. My power goal is 650+/- Think I'm in the ballpark?
Here's the set up so far. :
Gen 3.5 5.3 L59
VS racing Gen II billet 78/75 1.25 ar
BTR stage 2 turbo cam
BTR platinum .660 springs
LS7 lifters
LS9 head gaskets
ARP studs
TBSS intake manifold
SnakeEater Performance 1500cc injectors
Dual walbro 450s
E85
Fasster LLC fuel rails
HS hotside
4L80 - HD2 shift kit
Converter - undecided
Old Jun 7, 2019 | 03:51 AM
03sierraslt's Avatar
Who’s turbo kit are you running? Or are you gonna build it yourself? Should make for a nice combo, curious how the new Gen 2 7875 does.
Old Jun 7, 2019 | 08:39 AM
Huron Speed kit. I really liked their hotside kit. But comes with 4in intercooler, 44mm WG and 50mm BOV
Old Oct 14, 2019 | 09:59 PM
So this last weekend I finally started the build. First off was the motor work. I swapped cams with the BTR stage 2 turbo cam, BTR dual .660 springs, LS7 lifter and ARP head studs.
I would have taken more pictures but even when I work on my own stuff the flat rate mentality is ingrained in me so I'm trying to get finish as quick as I can.
Everything went smooth and took me a Saturday morning at work. Had to drill out an exhaust manifold bolt but nothing out of the ordinary there. Previous owner of the truck maintained it well, the inside of the engine was surprisingly clean.
Old Oct 15, 2019 | 11:16 AM
RA62025's Avatar
Banned
Matt at Sloppy Mechanics gained about 100hp all he did was go from Gen 1 to Gen 2. Take that how you want.
Old Oct 15, 2019 | 11:22 AM
Yeah I think Ill be good on that power goal. I think that should be pretty fun out on the street.
Old Oct 15, 2019 | 12:23 PM
Slammedcrew's Avatar
Nice, looking forward to the progress
Old Oct 15, 2019 | 02:48 PM
CarGeek's Avatar
Looking really good. I am in in the middle of my turbo build. I took the motor out instead, I thought it would be easier that way.
Old Oct 16, 2019 | 08:33 AM
ya I seen that, with like 8psi more maxed out. The real test is a back to back between gen1 and 2 on the same setup on the same dyno at the same boost. Just curious, it’s too small for my tastes but still interesting to see how they compare to each other.
Old Dec 22, 2019 | 05:32 PM
Couple updates. I’ve been traveling a ton for work lately so it’s been hard to get much done.
