Turbo 07 Sierra build
Old Feb 6, 2020 | 08:31 PM
  #21
03sierraslt's Avatar
Originally Posted by xKILLORADOx
I can only assume there will be a difference in the spool time on the 1.25 vs. the .96. just dont know how much.
You'll need a 4" downpipe with the 1.25 a/r. I want to be in the 700ish hp range. I know the .96 a/r is capable of that I just wanted to try something different. Honestly at the time I bought my turbo, close to 9 months ago, it was very new and not many had ran it yet,
If I was to start over though I think I would run the VS 80mm.
For 700hp you would most likely be better off with a 475/87
A 80mm compressor would be overkill for 700hp
Not that an 80 wouldn’t work, but just like pushing a turbo to hard, if you aren’t pushing it hard enough it’s also less efficient.
Old Feb 6, 2020 | 09:46 PM
  #22
xKILLORADOx's Avatar
Thanks,good to know,
This is my first turbo build and I used the sloppy Dont BS me build as a guide. I'm a GM master tech but havent really got too heavy into the performance side of things tell as of late. I think Ill be happy with my set up as it sits.
To be honest if it makes anything over 600 I'll be cool with that. It has room to grow as well.
Old Feb 7, 2020 | 09:48 AM
  #23
tjmath's Avatar
What fuel rails are you running? Everything looks good so far. Looking forward to seeing it all buttoned up and what she puts down.
Old Feb 7, 2020 | 10:10 AM
  #24
Ebay fasster rails. Theyre affordable and quality is great. I looked them over really well before installing and I had zero complaints.
https://www.ebay.com/usr/fassterllc?...p2047675.l2559
Old Feb 7, 2020 | 10:31 AM
  #25
tjmath's Avatar
They look real nice. And not a bad price at all. Nice find man.
Old Feb 24, 2020 | 01:41 PM
  #26
I havent been updating this thread as much as I should. I've made some progress over the last few weeks. I got everything to a point to where it could be started. Here are a couple crappy start up/idle videos I took. I was actually surprised it would start on the stock tune with the big injectors and e85 I splashed in the tank.
I'm getting closer! I have some odds and ends to button up. Then next will come the 80e swap when the torque converter shows up.
I post updates to my instagram more often if any of you are curious @st_turbo_truck
smitty418
Feb 17, 2020 11:18 AM
Mortiz
Jun 6, 2018 05:04 PM
Csnell3732
Mar 2, 2018 06:46 PM
holley2346
May 13, 2013 10:11 PM
mike06tork
Aug 15, 2008 08:54 AM
