Slow and getting slower
Old Nov 4, 2012 | 12:29 AM
  #1321
nonnieselman's Avatar
Ha thats funny!!!
i figured machine gun would be the two step..
Old Nov 19, 2012 | 11:41 PM
  #1322
Atomic's Avatar
I have a gauge for that
Working on a lot of upgrades lately. Getting the ball rolling on a 5" downpipe and slightly bigger turbo (82) with a bigger turbine. Scored some rancho 9000 shocks for the rear, upgrading the fuel pumps to dual walbro 400s, and added another meth nozzle. Speaking of which, this thing looks like something darth vader would go snorkling with
I actually need to play with the meth settings a bit more....may try a higher activation pressure and lower initial amount, but use a higher ramp rate. In any event, with the bigger pumps I estimate I have enough injector and pump for 1350rwhp without meth, so I wont need to use meth as a bandaid, just as cooling and knock suppressant.
I also put the old cam back in. Didnt see any improvements with the new one and driveability was worse. I think the lack of performance increase was due to the turbo turbine being too small.
I did some work on the damn plug wires to try to keep them from burning....I now have 3 really long ones, 3 normal ones, and 2 really short ones
Also, everyone should read this thread I wrote about pump flow and injector flow....if I had done this before the trip to the 1/4 I would have almost certainly got a 9 sec pass
https://www.performancetrucks.net/fo...p-flow-510434/
Heres the thread about my 1/4 trip a couple weeks ago. Managed a best of 10.4@129 running out of fuel due to too high of a base pressure. https://www.performancetrucks.net/fo...-1-4-a-510340/ I was also fitting burned plug wires the whole weekend and I think I replaced 5 or 6 of them before it was over, so I felt lucky to get 1 decent run...
Old Nov 20, 2012 | 12:04 AM
  #1323
smokeshow's Avatar
Mod with training wheels
That bigger cam would have liked the 82mm. Should move out with the turbo upgrade regardless.
Old Nov 27, 2012 | 12:55 AM
  #1324
Atomic's Avatar
I redid my fuel bucket using an 07 top part, and 04 lower bucket, with a 99 level sensor
Also installed these guys, starting out at 7/9.
Doing the test of jumping on the bumper seems 100 times better
Old Nov 27, 2012 | 01:14 AM
  #1325
smokeshow's Avatar
Ewwww brass fittingssss
Old Nov 27, 2012 | 01:25 AM
  #1326
Atomic's Avatar
Whats wrong with brass? Especially considering where it is...very corrosion resistant
Old Nov 27, 2012 | 01:31 AM
  #1327
smokeshow's Avatar
Oh, nothing...I was just mocking some people who were bitching about brass fittings in the past
Old Nov 27, 2012 | 01:34 AM
  #1328
Atomic's Avatar
Ah, well total cost in that setup is like $30 vs close to double that for an fittings that didnt work as well...
Old Nov 27, 2012 | 07:21 AM
  #1329
chevyboy.520's Avatar
I thought you were going to do 3 walbro 400's?
Old Nov 27, 2012 | 08:10 AM
  #1330
lglowe's Avatar
How big you end up going with the turbine? I hope as big as possible.... 96mm?
