Slow and getting slower
Old Aug 28, 2012 | 12:38 AM
  #1241
Atomic's Avatar
I have a gauge for that
Amazing they know more about it than me! Think it was obvious that is was mine?
I got these two:
Old Aug 28, 2012 | 12:42 AM
  #1242
smokeshow's Avatar
Mod with training wheels
This one was necessary
Grabbed a couple more...
http://turbojunky.com/img/p/53-166-thickbox.jpg
http://turbojunky.com/img/p/40-133-thickbox.jpg
Old Aug 28, 2012 | 09:57 AM
  #1243
chevyboy.520's Avatar
Some bad *** shirts for $5
Old Aug 28, 2012 | 03:38 PM
  #1244
black00chev's Avatar
Slowest turbo build ever!
See my avatar!!!
And that was me that said T6, I thought it was but I guess im wrong!
Old Sep 8, 2012 | 08:36 PM
  #1245
Atomic's Avatar
Found out why my bank 2 o2 was acting like it was misfiring at WOT...
Turns out its just a leak, not an actual misfire, so all is good. Probably needed to change the plugs anyway.
Todays big project was pulling the front diff and replacing both axle seals and the pinion seal. For anyone that plans on pulling the front diff, it sucks! You need to turn the wheels all the way to the left, move the diff down, then all the way to the right to be able to tilt it down enough to get it out.
Pretty dirty since the previous owner put over 200,000 miles on it and liked to offroad I guess...
After a little pressure washer and degreaser...
And everything inside looked perfect, which I expect because its an OEM setup.
I used some RTV on the case so hopefully it wont leak anymore, and also replaced the driver side CV since the boot was torn and throwing grease everywhere.
Old Sep 8, 2012 | 08:39 PM
  #1246
smokeshow's Avatar
I thought you said you could feel the misfire?
Old Sep 8, 2012 | 09:15 PM
  #1247
Atomic's Avatar
I said it felt like is was down on power...which with a good size exhaust leak will loose a lot of compressor speed, so it was probably in a different part of the map....or im just getting used to it
Old Sep 8, 2012 | 09:30 PM
  #1248
smokeshow's Avatar
You're probably just getting used to it. lol
Old Sep 8, 2012 | 10:33 PM
  #1249
1FastBrick's Avatar
Custm2500's Rude Friend
Looks like you blew an *** gasket...
is the flange distorted or did the nut on the stud just loosen up???
Old Sep 8, 2012 | 10:38 PM
  #1250
Atomic's Avatar
Maybe a little of both...the flange is pretty damn thick...
