RCSB LQ4/80E swap... Take two
Old Jun 13, 2016 | 06:16 AM
  #51
10 Second Club
That's the bed off of my old 2000, I had to straighten it some and get a new bedside. But, it was worth it because I prefer it over the fleetside bed.
Old Jun 19, 2016 | 10:07 AM
  #52
10 Second Club
I pretty much have buttoned up everything underneath. I still need to install an extra 02 bung in the pipe that crosses over from the driver's side. (For the wideband sensor) I have noticed one of my transmission lines leaking from where it goes into the fitting on the case. It was cracked around the flare. I cut off about a 10" section of the line. I'll go get an AN fitting and some hose to fix the connection. I installed the engine oil dipstick and coil packs on the passenger side. Still can't figure out my heater hose connections, they were brittle and leaking. I broke them off and picked up a new dorman replacement, no matter with do - it won't slip into the nipple if the heater core. Great...
I stuck my intake manifold on for mock up. Not happy with the TB at all. I am going to buy a Nick Williams 92mm. I have always had good luck with his TBs in the past. I tried to save a few dollars, and it didn't work out.
Attached Thumbnails RCSB LQ4/80E swap... Take two-img_20160619_100757615.jpg
Old Jun 26, 2016 | 06:15 AM
  #53
10 Second Club
I am liking the Nick Williams TB much better. I was able to make the throttle cable bracket that SDPC sells work. Took a few mods, but it will do.
Attached Thumbnails RCSB LQ4/80E swap... Take two-img_20160625_122304571_hdr.jpg
Old Jun 26, 2016 | 08:19 AM
  #54
Wolftrk99's Avatar
She running yet?? Tb looks good!!!
Old Jun 26, 2016 | 04:30 PM
  #55
10 Second Club
. Yeah, this is taking entirely too long. I didn't even work on it today. It's too hot and humid. I work in the heat and humidity 55-60 hours during the week, sometimes I need a break from everything. I am off this Wednesday, I plan to work on it in the morning. I dropped my PCM off for the tuner to install a base tune for me. Just something close so I can get it running. Going to work from the tune I had in my old truck as a starting point. If the planets align - I should have a full tune and dyno numbers in 3-5 weeks. It is hard to plan anything with my new job. My schedule is a bit odd.
Old Jun 26, 2016 | 05:14 PM
  #56
Wolftrk99's Avatar
Cant say much ive been working on getting my 6.2 together for going on 3 months now
Old Jun 29, 2016 | 12:04 PM
  #57
10 Second Club
The intake manifold is on for good. I need fasteners for the TB , the factory stuff won't work. I only spent a few hours on it today, the heat is unbearable.
Attached Thumbnails RCSB LQ4/80E swap... Take two-img_20160629_121857473.jpg   RCSB LQ4/80E swap... Take two-img_20160629_121904916_hdr.jpg
Old Jun 29, 2016 | 02:18 PM
  #58
About20ninj45's Avatar
Originally Posted by 86 IROC
Did more searching and reading yesterday evening. I think that I am just going to go with this for the sake of simplicity.
Walbro High Performance TU432HP Fuel Pump Module Assembly Assembly 550HP | eBay
Looked at this for a direct swap and ebay says its incompatable with my 2006 gmc yukon denali? is this a returnless style?
Old Jun 30, 2016 | 05:41 PM
  #59
10 Second Club
My truck is a 2001 with a return fuel system. I am running a C5 Corvette fuel filter for the regulator. I do believe that they offer a drop in replacement for newer trucks though.
Old Jun 30, 2016 | 06:16 PM
  #60
Wolftrk99's Avatar
Yeah the 432 is a return style pump.... iirc 464 is returnless..
