RCSB LQ4/80E swap... Take two
Old Aug 26, 2024 | 05:15 AM
  #171
10 Second Club
I'll just leave this here...
Old Aug 26, 2024 | 08:40 AM
  #172
smokinlmm's Avatar
That looks bad…
Old Aug 31, 2024 | 02:49 PM
  #173
10 Second Club
So... cliff notes:
last Sunday those bolts left the chat at a steady 70 mph. No idea why, never had converter bolts do that. Yesterday, decided to swap in that B&M 3400-3800 RPM stall that I bought a decade ago. I like the fact that it uses 6 bolts instead of 3 like my last 2 converters.
So far, good. Defintely feel the difference even normal driving. I went 1.81 60ft on the FTI in March, I definitely have a 1.7x in it this fall.
Old Aug 31, 2024 | 03:02 PM
  #174
smokinlmm's Avatar
The bolts in my FTI came loose several times and elongated the flex plate. Seems like a common complaint.
Old Aug 31, 2024 | 09:16 PM
  #175
10 Second Club
Originally Posted by smokinlmm
The bolts in my FTI came looseter. several times and elongated the flex plate. Seems like a common complaint.
Did not know that, maybe I need to extract the broken bolts and list it on marketplace. Other than the mishap, it's been a decent converter.
Old Sep 1, 2024 | 02:57 AM
  #176
smokinlmm's Avatar
I sold mine.
Old Nov 30, 2024 | 10:57 AM
  #177
10 Second Club
In the 12s with this hot garbage!
Old Dec 27, 2024 | 12:45 PM
  #178
10 Second Club
I hurt the rear back in November. Installed a new posi and bearings. SOB howls and whines bad above 45 MPH. Anything 60 MPH and above the vibration is terrible. I don't feel like the clearances in the gear set should have changed so drastically. I've been babying it to and from work. Bought another complete set of bearings and races. Going to pull it apart again, recheck EVERYTHING and install all new bearings again.
Talk about a thorn in my side...
Old Dec 27, 2024 | 03:33 PM
  #179
1FastBrick's Avatar
Custm2500's Rude Friend
But, did you measure the clearance before and after?
The gears are probably trashed now.
Old Dec 27, 2024 | 05:30 PM
  #180
10 Second Club
I did not, was in a rush to get it back in the road. Cheap, Richmond Excels that I've never been happy with from day 1. I should order a set of gears too, been pondering that.
