RCSB build
Old Feb 19, 2012 | 01:29 AM
  #261
N/ALS1's Avatar
Damn that sucks. In for reason of failure.
Old Feb 19, 2012 | 08:34 AM
  #262
mitchellmade's Avatar
MASS seller approved
nice run
Old Feb 19, 2012 | 09:29 AM
  #263
Beatdown Z's Avatar
Laid Back
Sucks the 6.0 died, but I can't wait to see how the 4.8 does with the weight and drag of a 4WD truck.
Old Feb 19, 2012 | 10:02 AM
  #264
Atomic's Avatar
I have a gauge for that
Originally Posted by smokeshow
Turns out the bearings and crank didn't play nicely, so the 6.0 has to come out for a full teardown/rebuild. Can't say why just yet, but improper lubrication looks to have played a part in its demise. Funny thing was the only sign of problems was low oil pressure. It made no noise out of the ordinary.
In the mean time I will be temporarily be jumping on the stock 4.8 bandwagon with foose04 and Most Hated, so the truck won't be benched while I rebuild the 6.0
exactly what happened to my 408
Old Feb 19, 2012 | 10:05 AM
  #265
foose04's Avatar
Saddle up, we got this!
You told me you wanted to keep your other stuff in place. That big damn S480 isn't in a t6 1.32 housing with a 96mm turbine is it? Even the 1.10 is going to be rough. I hope you have the 83 turbine and a good bottle heater, then we can get it moving out the hole.
Old Feb 19, 2012 | 10:11 AM
  #266
f4tal's Avatar
My buddy's 370/PT88 setups did the same thing. Ended up being a spun bearing. Stock 4.8 seems like the way to go these days. Building motors are a thing of the past... hahaha
Old Feb 19, 2012 | 10:52 AM
  #267
custm2500's Avatar
Ph.D. in HUBRIS
Defiantly a sleeper. Did it dead hook? Didn't hear any spinning but that is amazing for it to hook event in 4wd!
Good luck getting the engine back together soon.
Old Feb 19, 2012 | 10:54 AM
  #268
smokeshow's Avatar
Mod with training wheels
Yes it is the 96mm. It will be a frankenstein truck like I said...should still be fun, though. I don't go to the track for bracket racing so I don't need to build boost on the line in any short amount of time.
Old Feb 19, 2012 | 01:50 PM
  #269
foose04's Avatar
That's huge man...Not the compressor side, but the hot side. I bet you had a little lag with the 370.
I'd like you to enjoy it some while your getting rebuilt, but that hot side is past what I would consider drag only.
Old Feb 19, 2012 | 02:24 PM
  #270
smokeshow's Avatar
It does have a quick spool valve, so the lag wasn't too bad. Will certainly be a bit worse with the 4.8, but I can deal with it. If I had a manual transmission life would suck with that hotside...
