Project Nightmare
Old May 3, 2015 | 08:49 PM
subeone's Avatar
s475 t6 turbo is here, dwarfs that milk gallon lol
see's patiently waiting
got new durabond cam bearings put in by jr from craig caulk racing heads out of south houston, tx
another pic of the torque plate/boring process
using ARP head studs
main bearing clearance was left at .002" should loosen up once its broken into, will use 10-30 to break it in then maybe step it up to 10-40 weight assuming the clearance increases a bit after break in.
rod bearing clearances will be mic'd tomorrow and block should be good to be assembled and rings filed for boost. going with 28 up top and 30 on the mid ring, steel top ring.
Old Mar 2, 2016 | 09:39 AM
La RPM's Avatar
update thread noob
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
vipergtrdj
Sep 11, 2015 05:52 PM
