Project Nightmare
Old Apr 27, 2015 | 03:03 AM
subeone's Avatar
Default Project Nightmare
sup guys, just got my first truck couple of days ago. 02 black RCSB that was previously turbo'd. Got the truck very cheap, so decided to sell my foxbody project in order to fund this project.
I plan on doing a lil turbo setup on her... got a 4l80e already being freshened up, a super vic, 6160 elbow, 85 lb injectors, LJMS cam, BTR springs, e boost controller, autometer boost and tranny temp and wideband gauges on the way, T6 s475 is also on the way, and I will go with an on3 kit, modified a bit, to finish it off. Will keep this thread updated as new stuff comes by.
goal of this project is to trap at least a 130 mph at the 1320
Old Apr 27, 2015 | 08:07 PM
Byrdman11's Avatar
What turbine is in the s475? And what size engine?
Old Apr 27, 2015 | 08:20 PM
subeone's Avatar
Its gona be a 6.0 and the s475 has an 87.9 exducer wheel on the turbine
Should be good up to 800 hp i guess and will spray a 100 shot to get to the 1000hp possibly. Parts are on their way
Old Apr 30, 2015 | 01:49 AM
subeone's Avatar
Got some parts in today
got the 6061 elbow for my super vic intake
the quality is nuts! The elbow has a divider in the middle for even air distribution
precision gate also got here, 46mm on a 10 psi spring combination.
T6 hot pipes are done, big thanks to KB
cross over and 4 inch downpipe are top notch as well
also picked up a set of mahle pistons and eagle h beam rods, wasn't planning on forging the block but eh they were pretty cheap at 600 for the set, got a set of hell fire rings on the way as well as buying arp headstuds from a buddy!
boost gauge, trans temp gauge, and wideband also got here
autometers and an apsx d2 wideband gauge (uses bosch lsu sensor so thats good enough for me)
turbo and super vic with the rails should get here tomorrow, sent out the block to get bored over .030" so this will be a 370. BTR .660" springs get here tomorrow as well as my LJMS cam, melling HV oil pump, ls7 lifters, ls9 gaskets,3 bar map, and other crap!
Old Apr 30, 2015 | 03:25 PM
subeone's Avatar
got the super vic today as planned
LJMS cam, ICL advance should work well with this wet style manifold
got the block bored over today will hone it tomorrow ! then ready for assembly.
Old Apr 30, 2015 | 03:34 PM
Rafe19's Avatar
Well, this is going to be badass .
Old Apr 30, 2015 | 08:01 PM
Jake75's Avatar
Badass bro can't wait to see it run
Old Apr 30, 2015 | 08:09 PM
walledition's Avatar
Really nice, did the little dump pipe for the wastgate come with astegate or where did u get it if u dont mind me asking?
Old Apr 30, 2015 | 11:13 PM
subeone's Avatar
KB racing did it for me! Real good guy!
Some more updates, got the tial BOV's the BTR springs, the oil pump, 7.400 pushrods hellfire rings etc
Old Apr 30, 2015 | 11:14 PM
subeone's Avatar
Heres a pic of all the stuff
