Project Man-Van
Old May 25, 2013 | 01:56 PM
  #361
Spoolin's Avatar
GFYS and STFU
Originally Posted by Chevy_freak
Im really contemplating a van now since I looked at a 4wd converted dmax.
My friend who will be helping me do the 4wd conversion figured out a way for me to have IFS 4WD while also being able to have airbags on all four corners. I don't want to go solid front axle because of the weight, ride characteristics and functionality of it, as well as the aesthetics of it. But a 4wd duramax van is probably IMO the epitome of a badass multi-purpose rig!!
Just not sure I want to limit myself to a bumper pull. Having a gooseneck has been really convenient.
So far that is really the ONLY drawback to this whole experiment. I'm getting a toy/car hauler trailer built right now and it'll be a bumper pull obviously but the idea of a 5th wheel was something I really really wanted. I know the bumper pull will work great and all but having the capability of hauling a 5th wheel would of been great!
(and for those of you that are gonna suggest cutting up the van like some of those other hack modded vans...don't! That's a bit too for me!)
Old May 25, 2013 | 06:11 PM
  #362
Spoolin's Avatar
GFYS and STFU
Originally Posted by ak2007r6
Hopefully I don't ***** your thread up to much but here is the projector retrofit I did on my motorcycle. Might be somewhat helpful.
How did you separate the reflectors from the housing? They are connected via ball joints in the back and I can't get to them and have no idea how much pressure to apply without breaking them?
Kinda looks like this....
Old May 25, 2013 | 10:20 PM
  #363
Benlugchev's Avatar
11 Second Club
This is turning out to be a sweet rig. Nice work man.
Old May 25, 2013 | 10:27 PM
  #364
ak2007r6's Avatar
If I remember right I believe the ones on the motorcycle were just held in with screws/bolts. Let me see if I can find a better picture.
Are you planning on reusing the reflectors?? Could always build your own custom shrouds around the projectors. That's what I did with some think pliable rummer sheet stuff.
Old May 25, 2013 | 10:32 PM
  #365
ak2007r6's Avatar
Here is the backside of the reflectors. They had 3 bolts that held them in which is what I used the bracket later on for to mount the projectors.
Old May 26, 2013 | 12:08 AM
  #366
Spoolin's Avatar
GFYS and STFU
Ok yeah, they're a bit different from your motorcycle ones. I was playing around with it a little and I don't think it necessary to pull them apart anyways so I'm just gonna work around them. I spent about 3 hours today on them but I need to buy a dremel at Home Depot so maybe I'll get it done tomorrow.
I am re-using the reflectors, I just painted the low beam half black. Will be interesting to see how it all looks when completed. Gonna test fit it all and depending on how it looks I might do projectors on both high's and low's. Not sure yet...just gonna see how it all works out.
Will have a better updated tomorrow hopefully.
Old May 26, 2013 | 12:13 AM
  #367
ak2007r6's Avatar
Nice. When I get projectors put into my truck I will be doing low's and highs. There is a guy locally on Craigslist that is advertising that he does them, might go check out his work and see if it's worth paying him to do it.
Old May 27, 2013 | 02:27 AM
  #368
Spoolin's Avatar
GFYS and STFU
Welcome to my current Project/Nightmare!! :/
Will do a write up when it's all done but this is not as straight forward as I thought/hoped it was gonna be!!
Old May 27, 2013 | 02:31 AM
  #369
ak2007r6's Avatar
no.. no it's not. I did that retrofit on my motorcycle and though opening up my truck headlights would be a breeze. I was mistaken.
Good luck man, will look and perform badass when done. Take your time.
Old May 31, 2013 | 01:27 AM
  #370
Spoolin's Avatar
GFYS and STFU
Well...the Nightmare is over!!!
I'm waiting for the silicone to dry on them and then I can drop them in, but before that, here's all that I had to do to make them work. Have a seat ya'll and grab some
So here's what I started with, Projector conversion and a aftermarket set of new headlights:
First thing I had to do was do a little baking:
Then Pried them apart (man was that some nasty stuff, but thankfully once it's warm it comes apart pretty easy...considerably)
Then I taped off the Hi-Beam reflector and painted the Low-beam black with some Flame proof non-reflective paint.
So this is the hole that I started out with that I had hoped I didn't have to modify:
Seemed like it would fit in pretty well with no mods necessary!!
But unfortunately it was not meant to be. First there was not enough thread left in the back to be able to install the bulb retaining clips...
So after 1 hour of grinding to make that work, I put it all back together to find out that the top of the projector would hit the back side of the headlight lens when I put it back together. So I had to grind the living snot out of the reflector to get the projector to sit recessed inside the reflector enough so it wouldn't hit the back of the lens cover.
So started the grinding....
