Project Kermit
Old Oct 8, 2009 | 12:44 AM
  #881
thunderwagen's Avatar
Those are good numbers for how low your cr is. I'm getting mine tuned N/A on friday. I'm at 9.5 cr with a GT2-3 cam and AFR 225 cc heads. Hopefully it is over 300rwhp. Once I figure out what kind of FI I'm going to put back on it and I recoupe some funds I know boost will be my friend again.
Old Oct 8, 2009 | 01:05 AM
  #882
nonecktribe's Avatar
i think you will be in that area wut size motor?
Old Oct 8, 2009 | 01:45 AM
  #883
dc_justin's Avatar
Hello Dave
Originally Posted by Spoolin
Well in that case not bad for a 0.0 ci engine then too!!
btw Justin thinks your trucks' a turd and I'm gonna smoke you on Saturday...
I wonder if Justin reads this thread and is aware that I'm putting words in his mouth
And for anybody looking to compare this dyno graph to others. On a DynoJet (or any other dyno that tries to emulate a DJ), the power numbers are artificially INFLATED by almost 20%. Julien would have seen around 375hp on one of those dynos.
This thing runs absolutely nothing like a stock 5.3L and really surprised me considering the setup.
(http://www.factorypro.com/magazine/d...hp_reason.html)
Old Oct 8, 2009 | 02:17 AM
  #884
Spoolin's Avatar
GFYS and STFU
Awww... I feel like I got caught by the teacher for passing a note in class!!
I guess you do read this thread!
Thanks again for the help and everything else!! By the time you move out here I should have something set-up that will really challenge you!!
Old Oct 8, 2009 | 04:25 AM
  #885
Forged 370. I know it was fun with 11# of boost.
Old Oct 8, 2009 | 08:30 AM
  #886
trever1t's Avatar
2nd fastest 5.3 ECSB
so my estimate wasn't that far off ehh?
Old Oct 8, 2009 | 09:38 AM
  #887
LsxCody's Avatar
Damn. Pretty good numbers for low cr
Old Oct 8, 2009 | 01:44 PM
  #888
ButlerBoy's Avatar
I like the way your truck is set up. You probably cover it somewhere else but I just joined and haven't had time to go through all 89 pages yet, could you tell me more about your suspension, wheels, and your brakes? I'm guessing 4/6 drop, looks like SS rims so they are 20's right? Are you running a 40 series tire? And I MUST find out more about the brakes. With as big as the calipers are I'm guessing 6 piston. Are they off a vette or are the aftermarket?
Old Oct 8, 2009 | 01:46 PM
  #889
Spoolin's Avatar
GFYS and STFU
Originally Posted by GMCtrk
...That out of boost torque is pretty similar to a stock 5.3, which is a turd driving around. Personally I just don't think I could deal with that lack of cruising power. Although you do have the lighter weight of the reg cab....
I pulled up my stock 5.3L dyno sheet and the curve is somewhat similar but in much much different location, duration and it especially the length of it, mine right now seems to carry pretty far! The difference is evident by the 58hp difference. Also take note that they are behind different transmissions. Kinda interesting though.
Definitely fun to drive!
Stock 5.3L behind a 4L60e....
N/A low comp 366ci behind a 4L80e...
Old Oct 8, 2009 | 01:56 PM
  #890
Spoolin's Avatar
GFYS and STFU
Originally Posted by ButlerBoy
I like the way your truck is set up. You probably cover it somewhere else but I just joined and haven't had time to go through all 89 pages yet, could you tell me more about your suspension, wheels, and your breaks? I'm guessing 4/6 drop, looks like SS rims so they are 20's right? Are you running a 40 series tire? And I MUST find out more about the breaks. With as big as the calipers are I'm guessing 6 piston. Are they off a vette or are the aftermarket?
Hey...
-As far as the brakes go they are 6 piston front's on 16" rotors made by wilwood for our trucks. Rear's I believe are 4 pistons on 14" rotors, same deal with wilwood. They come as a package called the big brake kit.
-Rims are SS rims yet, they are powdercoated a Flat black. Tires are 50 series Nitto's.
-Drop is a mystery to me, it's kind of a mix of parts from various companies (DJM, bilstein, etc...) so it's a little odd ball in number but it's between a 2/4 and a 3/6. And the rear is C-notched which accounts for the drop back there.
