Project Kermit
#362
Were some of those friends the hot neighbors? If you'd ever post up some pics of them, I could prolly offer better help.
Really now, no wiring harness or anything pinched somewhere that may've been overlooked? BTW, the pan looks pretty sorry lookin, between the smashed spots & the "RTV" work.
#363
GFYS and STFU
I guess that's a possibility...Never really looked at them that closely, aren't they reversible?
The fitting in the oil pan looks like a temp sender. I guess the one that comes from the factory inside the transmission just isn't good enough.
That is a little strange where the trans mount is sitting on the crossmemener. Can you turn it around the other way to move the stud back toward the rear of the truck?
#364
GFYS and STFU
you know I'm gullible right??
I don't think so but I'll have to check again, and that pan doesn't have many dents on it, I think it's the design of it. I'll try and get a better shot of it at some point but if the pan is totally trashed I might have to get a new one.
#365
I think I remeber some one saying they had similar trouble with having the frame mounts back wards. there is a motor mount on the block and then a frame mount. I think The frame mount might be the one thats back wards. I think the actual motor mount is reversible but not the frame mount.
Something to look at any way...
#366
I wasn't sure on the dents, if part of design, since I only knew the basic pan shape. New pans that hold additional fluid are an $$ option, the nice versions are IIRC, I'm thinkin ~$150. More capacity usu. 2 or 3 QTS, often thicker, & drain fittings.
#367
GFYS and STFU
Fun fun fun fun!!!
The curious thing is that all the bolts lined up on the frame mount bolts so if they aren't reversible I wonder why all the bolts still lined up.
#370
GFYS and STFU
Bring me your parts truck so I can go through it and tear what I need out of it!!
