Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Jan 1, 2007 | 07:20 AM
  #921
FLT's Avatar
FLT
FormerVendor
When is thing going to be done? I had heard of dates much sooner! I guess shooting for sometime in 08 would be a good goal. J/K Looks good and I'm sure you will be happy when it's finally done. Also because you did alot of it yourself you will really appreciate it more. Good luck with the final results Devin. Vince
Old Jan 1, 2007 | 12:40 PM
  #922
Wilde Racing's Avatar
How do I change this text
Wow that looks way good, I agree with Turboberserker. mock up be fore you change anything!
Old Jan 1, 2007 | 06:36 PM
  #923
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why didnt you paint the mainfold too?
Old Jan 1, 2007 | 07:44 PM
  #924
moregrip's Avatar
what a rush!
well, I've been through a few iterations now, currently it's in a sanded, ready for paint condition........which btw........I really like! wonder if there is a way I could just leave it like this?
Old Jan 1, 2007 | 08:04 PM
  #925
1slow01Z71's Avatar
VHT sells a clear coat that looks really sweet and will "seal" in what ever finish you currently have. Most people that paint their blocks use the clear too.
Regular enamel PN VHT-SP145
Polyurethane enamel PN VHT-SP29
Not sure which one you want to use.
Old Jan 1, 2007 | 08:29 PM
  #926
moregrip's Avatar
what a rush!
new tattered grunge look!
Old Jan 1, 2007 | 09:11 PM
  #927
1slow01Z71's Avatar
How are you keeping the black paint dust from getting on everything. When I painted my block that crap drifted everywhere, it didnt stick but it left a sort of paint "dust" on alot of stuff.
Old Jan 3, 2007 | 01:35 PM
  #928
moregrip's Avatar
what a rush!
common practice is to wet the floor before you paint, you can make a pretty decent paint booth with plastic sheeting, a wet floor, and a home box fan pulling air from inside.
I didn't do any of that, just prepped and painted, came out pretty good the first time so I didn't mess with it........
Old Jan 3, 2007 | 07:18 PM
  #929
moregrip's Avatar
what a rush!
looks like we have a winner!, Crank Damper Issue's are solved now
the problem:
Stock damper bolt is approx 100mm long
Replacement bolt for Innovators West damper for a vette application (what I have) 130mm long; What I actually need is a bolt 180mm long! doh!
stock bolt, 130mm bolt vette guys use with Innovators West Damper, 180mm Bolt needed for Innovators West Damper (truck application)
machined nylon to hold crank keyway in place when bolt is tightened (sandwiched), this is the correct length for vette applications, I'll need a different length for my truck application........
Old Jan 3, 2007 | 07:29 PM
  #930
Bill Reid's Avatar
Originally Posted by moregrip
[B][COLOR=DarkOrange]looks like we have a winner!, Crank Damper Issue's are solved now
Details bro ... get the right length of nylon spacer or what?
Bill
