Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Dec 27, 2006 | 03:40 PM
  #881
moregrip's Avatar
what a rush!
Originally Posted by Bill Reid
I guess you could put some wax or clay on the end of the bolt and snug it down and see what actual room you have?
thats the actual room I have 2.642mm, does it sound like enough?
Old Dec 27, 2006 | 04:03 PM
  #882
kbracing96's Avatar
Just make sure the threads go all the way to the bottom of the hole
Old Dec 27, 2006 | 04:05 PM
  #883
moregrip's Avatar
what a rush!
not following what you mean or are implying???
Old Dec 27, 2006 | 04:10 PM
  #884
kbracing96's Avatar
Just because the hole is deep enough, doesn't mean that the threads were cut all the way to the bottom with a bottoming tap.
Old Dec 27, 2006 | 04:14 PM
  #885
kbracing96's Avatar
I think I see the reason for confusion after re-re-reading the tread, your talking about how much thread will be left on the bolt and I'm talking about how deep the hole in the snout of the crank is. I think where on the same page now
Old Dec 27, 2006 | 04:22 PM
  #886
moregrip's Avatar
what a rush!
the threads on my crank are the smallest ID portion of the crank snout hole, behind the threads is a concave area, and in front of them is an ID roughly the same measurement as the valley of a crank thread. What I am referring to is how much room I will have from the time I start to torque the crank bolt(starting from a snug fit) to where the bolt physically "bottoms out". That distance, for me presently, is 2.642mm. My question is, does that sound like enough distance? I suspect it is.
Old Dec 27, 2006 | 04:38 PM
  #887
kbracing96's Avatar
Humm.... might be a little tight, probable be ok, but could always grind a little off the end if the bolt just to make sure.
Old Dec 27, 2006 | 06:07 PM
  #888
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Those ARP packets with 12 point ss bolts look familiar
Suckers are expensive arent they
Old Dec 27, 2006 | 09:07 PM
  #889
moregrip's Avatar
what a rush!
they ain't cheap......
anyone else have any input about the crank bolt clearance question?
Old Dec 27, 2006 | 09:09 PM
  #890
I am no where near experienced with it but to ease your mind, I know that bolt is torque-to-yield but I don't think it would stretch more than 2.5mm
