Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#3161
I think it was a combination of rear pinion angle too low and carrier bearing not high enough. I have some aluminum bar that I was going to experiment with for the transmission mount laying around somewhere as well. The airbag kit shouldn't have a problem working as long as you have enough clearance between your tires and frame. I think 5 inches is needed. Here's the included directions: http://www.jegs.com/InstallationInst.../022-59209.pdf Some fabbing/cutting will be required with this kit. I dug up what I have, I have the airbag kit #59209, a torsion bar tool, and some aluminum bar for spacers if needed. What would you like? With either a sway or panhard bar, some fabrication is going to be needed. I explored both and there are several kits out there for trucks, but mostly the lifted ones. Check your PMs. Just remember that I'm eastern time please.
