Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 12-08-2011, 07:00 PM
  #3161
what a rush!
moregrip's Avatar
Originally Posted by Bimmer Tech
I think it was a combination of rear pinion angle too low and carrier bearing not high enough. I have some aluminum bar that I was going to experiment with for the transmission mount laying around somewhere as well. The airbag kit shouldn't have a problem working as long as you have enough clearance between your tires and frame. I think 5 inches is needed. Here's the included directions: http://www.jegs.com/InstallationInst.../022-59209.pdf Some fabbing/cutting will be required with this kit. I dug up what I have, I have the airbag kit #59209, a torsion bar tool, and some aluminum bar for spacers if needed. What would you like? With either a sway or panhard bar, some fabrication is going to be needed. I explored both and there are several kits out there for trucks, but mostly the lifted ones. Check your PMs. Just remember that I'm eastern time please.
seems like there is going to be a bit of trial and error with drive-line angles once everything is installed.....but it sounds like when it's all said and done it will be a fairly kick *** setup!
Old 12-18-2012, 10:03 PM
  #3162
mdwatts11's Avatar
I hate to dig this up from the dead, but I just read the whole thing again and I'm just curious as to what's going on with the truck. I love the build and all of the great craftsmanship.
Old 12-19-2012, 05:54 PM
  #3163
what a rush!
moregrip's Avatar
It's secure in an undisclosed location! Carrier bearing took a poop on me
Old 12-19-2012, 07:31 PM
  #3164
mdwatts11's Avatar
So you never demodded it?
Old 12-19-2012, 09:08 PM
  #3165
what a rush!
moregrip's Avatar
No....still all together.........
Old 02-14-2013, 09:20 AM
  #3166
what a rush!
moregrip's Avatar
dropped off my drive-shaft to SuperCharger Connection to get the carrier bearing replaced. Bearing is fine but the rubber surround is broken appart....too many WOT wacks I suppose. Nothing BC can't handle!!! Thanks brother!
Old 02-14-2013, 10:16 PM
  #3167
Registered User
1320GearShop's Avatar
Thanks for digging up the thread, all I can say is wow!
Old 02-14-2013, 11:43 PM
  #3168
Custm2500's Rude Friend
1FastBrick's Avatar
Talking
Sound's like a real pile of junk... Let me do you a favor and take that problem off your hands
Watch out for BC. I hear he likes large shafts and Blowing things... That's why he's the Blownerator
Old 02-17-2013, 01:44 PM
  #3169
what a rush!
moregrip's Avatar
lol, I think I'll hold onto my pile of junk a little longer
Every time I drive this thing I forget how flippin fast it is! woot!
Old 06-13-2013, 09:34 AM
  #3170
blownerator
BlownChevy's Avatar
I am proud to say that I am the new owner of the WORLDS LONGEST BUILD THREAD.
Stand by for Dyno Numbers Soon.
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
