Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Nov 1, 2006 | 07:41 PM
  #301
moregrip's Avatar
what a rush!
transmission yoke:
Old Nov 1, 2006 | 08:10 PM
  #302
moregrip's Avatar
what a rush!
so now the question I have is, what is the critical measurement I need to pay attention to?
is it the difference between the rear driveshaft and pinion? or is it the difference between the tranny angle and pinion angle? or all three?
at least I know my starting measurements where I experienced zero problems.....
Old Nov 1, 2006 | 08:13 PM
  #303
XLR8NSS's Avatar
Adkoonerstrator
So this is a little bit off topic but, why do some trucks get a 2pc setup and some get a single setup? Which trucks? My Dad's Dmax ECLB has a one piece MONSTER aluminum shaft.
  #304
I was thinking you altered your suspension. Dammit!
So you have roughly 5* of pinion angle I assume. Are these negative *'s or positive? How do you know?
That's subtracting your actual pinion (diff nose) and your driveshaft angle going into the differential. I thought that's how you measured it.
Anyone else on how to get a pinion angle?
Jim
Old Nov 1, 2006 | 08:17 PM
  #305
moregrip's Avatar
what a rush!
So you have roughly 3* of pinion angle I assume. Are these negative *'s or positive? How do you know?
Jim
according to my measurements I have +3deg pinion or nose up (93deg)
and my rear driveshaft is 98deg
93deg(pinion) - 98deg(driveshaft) = -5deg
is this correct?
Old Nov 1, 2006 | 08:24 PM
  #306
Question
I thought you subtracted the 8* driveshaft angle and the 3* diff angle. I mean, just measuring the actual diff noses angle will not get you the proper pinion angle in relation to the driveshaft's angle. If that truck was lifted, then the drive shaft angle would be quite a few more degrees. The diff's angle would still be at 3*.
So, with that example, the actual way to get a proper pinion "angle" you would need to be subtracting something in relation to the actual diff nose angle.
Am I right?
Jim
Old Nov 1, 2006 | 08:26 PM
  #307
is this correct?
I actually ment to put 5*. It being neg or positive is what I'd like to know as well.
Jim
Old Nov 1, 2006 | 08:28 PM
  #308
moregrip's Avatar
what a rush!
Am I right?
Jim
yes, as I understand it, you subtract the driveshaft angle from the pinion angle. In my case 93deg - 98deg or +3* - +8*
Old Nov 1, 2006 | 08:30 PM
  #309
Here, read some of this:
I'm still reading it as well. Let me know what you think.
http://www.carcraft.com/howto/91758/
Jim
Old Nov 1, 2006 | 08:33 PM
  #310
moregrip's Avatar
what a rush!
Jim
I was looking here:
angles
