Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Feb 10, 2009 | 05:42 PM
  #2891
moregrip's Avatar
what a rush!
staying returnless for now, very much like what I had before
Old Feb 11, 2009 | 02:35 AM
  #2892
SuperchargedSS's Avatar
need MORE!!!!!!! Must...see...more!!!
Old Feb 13, 2009 | 07:59 AM
  #2893
DrX's Avatar
DrX
How do I miss this stuff?? Need to check out the Pojects Gallery more often. Lookin good Grip!
Old Feb 14, 2009 | 06:00 PM
  #2894
moregrip's Avatar
what a rush!
thanks brother!
Update:
Starting the project today I've got everything I need to complete the install minus a TBSS or SSR Evap/Purg Valve and a bracket that's being made.
Currently fabbing mounts for the CTS-V heat exchanger, has taken me a while to figure out a way to mount it I'll be happy with.
Thanks BC for all the assists!
Old Feb 14, 2009 | 06:03 PM
  #2895
GMCtrk's Avatar
Hey, Moregrip,
Did you modify your 4l80e's pump to work with the PI converter? I'm looking at going with the 10.5" 3000 myself with the 80e.
Old Feb 14, 2009 | 06:09 PM
  #2896
moregrip's Avatar
what a rush!
Originally Posted by GMCtrk
Hey, Moregrip,
nope, why, are you running into an issue?
Old Feb 14, 2009 | 06:21 PM
  #2897
moregrip's Avatar
what a rush!
and so she begins.......................again:
Old Feb 14, 2009 | 06:28 PM
  #2898
moregrip's Avatar
what a rush!
I don't have the converter yet, but I was reading PI's installation manual in PDF format and it says that the converter comes with a spring that you install into a valve in the pump. I searched and there was also a couple threads about it here by Bill Reid and KySilverado.
Here's a picture of it courtesy of Bill Reid. It's the red spring and apparently you have to grind down that notch to get the spring to fit over it.
Here's a quote from Vince @ FLT. If I'm reading this correctly Parish ran without the spring mod just fine. If everything works fine without the mod, I'd rather not tear into anything.
Also, I see you have the 2800 stall speed. How do you like it? I've read the 3000 is a lot like stock just driving around normally but is really nice when you get on it.
Thanks
Michael
(just picked this up last night - happy as a tit)
I did not do that step when I put in the shift kit with the stock converter. California Performance Transmission built my current tranny and prior to the build I told them what converter I was running. That's all I can say about it, sorry not much help. Congrats on your new parts!
I haven't had much time to play with the new converter, but so far it seems to drive just fine.
Old Feb 14, 2009 | 06:50 PM
  #2899
supersub's Avatar
here is a few of mine to help get you started....
Old Feb 14, 2009 | 07:01 PM
  #2900
moregrip's Avatar
what a rush!
thanks bro, going with something very close to that
