Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old May 2, 2008 | 09:12 AM
  #2421
custom 68's Avatar
[QUOTE=moregrip;3910785]
If it's not ready to start by this weekend I may just end up long term storaging it. QUOTE]
Wow good luck, so that really only gives you 1 or 2 days of working.
Like asked how long will you be shipped out and thanks for your service...
Old May 3, 2008 | 12:29 AM
  #2422
moregrip's Avatar
what a rush!
got some more work done today.............had to re-route the whole lower half of the harness.............apparently I forgot how we laid it out (A FEW WIRES RAN SHORT) so we fixed all that; which of course took quite a while; BUT, at least everything hooks up ok now!
So where am I?
let's see:
I'm ditching Magnuson's I/C cooler wiring & Nelson's E-Fan harness and going with a different setup, simplified "so to speak"
I need to tidy up some of the wiring with zip ties and get all my electrical connections finalized.
Make the new I/C pump/E-Fan/Heat Exchanger Fan Harness built and installed.
Tighten down some Misc bolts.
Connect the new Battery so I can run the fuel pump and clean out the lines.
Pre-Lube the Engine with 30wt Break-In oil.
Load Tune and then "Fire in the Hole"!
I suspect I have 1 more solid day of work (tomorrow) and Sunday we can Fire it up, check for leaks, and start tuning. That leaves me two full weeks to drive it before I shove off.
Got the new HD Tensioner on the work-bench and ordered a new set of idler pulleys in the event I have issues with my current setup.
Old May 3, 2008 | 10:03 PM
  #2423
moregrip's Avatar
what a rush!
plenty left to do................BUT.....................I'm starting to get excited!
wheeeeeeeeeeeeeeeeeeeeeee!
Old May 3, 2008 | 10:06 PM
  #2424
trever1t's Avatar
2nd fastest 5.3 ECSB
Get 'er done buddy!
Old May 3, 2008 | 10:47 PM
  #2425
moregrip's Avatar
what a rush!
where in the "Blue ****" does the large Battery Ground wire connect too?
Old May 3, 2008 | 11:17 PM
  #2426
1Bear's Avatar
Should be the side of the block, behind the power steering pump.
Old May 3, 2008 | 11:22 PM
  #2427
moregrip's Avatar
what a rush!
same place the rear bracket to the power steering pump bolts too?
Old May 3, 2008 | 11:40 PM
  #2428
1Bear's Avatar
You should find the spot located between there and the motor mount, located just above the oil pan rail.
Old May 4, 2008 | 08:01 AM
  #2429
custom 68's Avatar
I bolted mine to my head a spot that was convenient (sp) but I got new ones from teh parts store
Old May 4, 2008 | 08:30 AM
  #2430
Wilde Racing's Avatar
How do I change this text
how did you wire up your fans, if you dont mind me asking??
