Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Apr 26, 2008 | 08:03 PM
  #2391
BigCountryx's Avatar
Originally Posted by moregrip
1. hook-up / re wire wideband
2. wire Kenne Bell Boost A Pump
3. re wire magnacharger intercooler pump (lengthen wires)
4. finish routing starter / knock sensor / a/c / ground wires
5. wire heat exchanger e-fans
6. re-install nelson e-fan harness for main fans
7. re-install boost & fuel pressure lines/wiring
8. flush main fuel line, re-install all fuel lines
9. fill engine with oil via engine pre-luber
10. load tune and fire!
So.....should be done by morning. lol sounds like the home stretch now bud, good luck.
Old Apr 26, 2008 | 10:33 PM
  #2392
moregrip's Avatar
what a rush!
Standing Duty again today, might get some time tomorrow or Monday, hopefully finish it up by Wed, Tune Thurs/Fri, drive by next weekend!
Old Apr 27, 2008 | 07:37 AM
  #2393
03sierraslt's Avatar
Can you still find the keys for it?
Old Apr 27, 2008 | 09:07 AM
  #2394
OnyxSilveradoSS's Avatar
LOL...I wonder if the key fob battery is dead
Old Apr 27, 2008 | 11:28 AM
  #2395
j225's Avatar
I was curious why you don't like dumps?Is it that (hell i don't know how to describe the sound of turndowns)
Old Apr 27, 2008 | 03:36 PM
  #2396
zippy's Avatar
That's pretty cool. I was wondering if you were even going to be driving it this year.
Old Apr 27, 2008 | 10:11 PM
  #2397
moregrip's Avatar
what a rush!
got a fair amount of work done today......
Re-installed the remote mounted boost and fuel pressure senders....added a T in front of the boost sender and remote mounted the Hobbs switch for the KB BAP, turned out pretty nice.
Got the wide-band wires routed/re-installed(not exactly where I want it to go but good enough for now you know.
Battery looks to be dead, had it on the trickle charger for the last few days, only getting 10.8 volts
ended up mounting the KB BAP on the old Magnacharger I/C reservoir bracket(again, not my first choice but it ended up being a time saver non-the-less).
other small details.....such as having to bend the alternator to battery bracket 90 degrees vs. the stock 45 degrees due to the new wire routing.
Went through and started tightening up all the things I kept thinking "I'll get to it"
Re-installed blower belt, basically a bunch of small tasks.
Old Apr 27, 2008 | 11:16 PM
  #2398
BlownChevy's Avatar
blownerator
25 Year Member
Good job D.......glad you are getting it done.
Old Apr 27, 2008 | 11:19 PM
  #2399
moregrip's Avatar
what a rush!
thanks bro, working on it as much as I can
Old Apr 28, 2008 | 06:43 AM
  #2400
zippy's Avatar
How long before you end up getting shipped out again? It's gotta be nice weather out there by you guys, I'd hope your enjoying some of it.
