Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Nov 9, 2007 | 12:00 PM
  #2121
SlvrSierra4.8's Avatar
Originally Posted by moregrip
as long as the above routing is correct adding the larger tranny cooler turned out MUCH better than I expected.
Didn't need any aftermarket lines, just 2 inverted flare to -6AN adapters, 2 -6AN tubing nuts/collars, and one 90deg -6AN fitting. Made two bends with a handheld bender (one 25deg inlet side, one 90deg outlet side); next cut off the factory ends; then flared them to 37deg, done, call it good. Turned out super clean and here's what I did:
view from the front:
Grip, was curious of what brand cooler is this was of how you mounted it? Did you make your own brackets? TIA
Old Nov 9, 2007 | 06:00 PM
  #2122
moregrip's Avatar
what a rush!
hey bro, thats a tru-cool tranny cooler I painted black. I made a lower bracket out of home depot aluminum and the stock cross bar, also painted black, upper mount is some home depot aluminum flat bar and a radix I/C upper bracket
Old Nov 9, 2007 | 09:20 PM
  #2123
moregrip's Avatar
what a rush!
Default test-fit/evaluation; drivers side valve cover is on!
I think this looks decent
Old Nov 9, 2007 | 09:47 PM
  #2124
Bill Reid's Avatar
Yup
Old Nov 9, 2007 | 10:15 PM
  #2125
moregrip's Avatar
what a rush!
Originally Posted by Bill Reid
Yup
thanks Bill, here's a pic of them with the chromed valve cover brackets, stock coils, Taylor plug wires, and home polished stainless hardware:
Old Nov 9, 2007 | 11:08 PM
  #2126
Bill Reid's Avatar
Super nice. The big Taylor's are bad azz. I am REALLY SUPER interested in how you will lay out your harness. I have a complete undamaged 04 2WD 6L/4L80E harness I will be converting to eFans...
Bill
Old Nov 9, 2007 | 11:09 PM
  #2127
moregrip's Avatar
what a rush!
Super nice. The big Taylor's are bad azz. I am REALLY SUPER interested in how you will lay out your harness. I have a complete undamaged 04 2WD 6L/4L80E harness I will be converting to eFans... and I am VERY interested in how your will lay things out.
Bill
Yeah and they fit well(the Taylors)...........I really only have two things left to work on, exhaust and wiring so you won't have to wait much longer
Old Nov 10, 2007 | 10:34 AM
  #2128
03sierraslt's Avatar
Man this build has taked FOREVER....................................... I will say one thing though.. When you do it, you do it right. Awesome attention to detail brother, cant wait to see/hear this thing running.
Old Nov 10, 2007 | 10:43 AM
  #2129
moregrip's Avatar
what a rush!
once I didn't make my initial goal date, it stopped being a race to get it done, rather, get it done right, at least in my mind.
that said, I am getting ready to short order a few steps in the interest of time so I can enjoy the truck for a few months before I deploy
Old Nov 10, 2007 | 10:46 AM
  #2130
Bill Reid's Avatar
How long is the deployment?
Bill
