Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2101
had duty yesterday, a few things showed up while I was away:
first I figured I'd take a few pics of the engine pre-luber so you guys can get an idea of how it works:
took a picture of it next to a gallon of coolant to get an idea of its size:
various fittings for different engines:
hand pump and 6.0L fitting installed:
close-up of valve and 6.oL fitting:
instructions:
oil gallery location used:
instructions:
#2106
GFYS and STFU
I think the stock ones will complement the blingin you've got going on better than custom ones. You were looking at custom ones that were carbon fiber right? If you do go custom see to it that it's polished like the rest of your goodies!
#2107
You're good to go as is . . . so go as is!
BTW, thanks for the info on the pre-luber. By injecting the oil at the front oil galley, the oil passes through the filter before being fed upward to the cam journals. It's also the easiest place to get to.
Steve
Steve
#2108
#2110
