Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Oct 11, 2007 | 04:37 PM
  #1991
zippy's Avatar
You're slowly running out of things to install and re-assemble. This is starting to get good.
Old Oct 11, 2007 | 05:26 PM
  #1992
moregrip's Avatar
what a rush!
need a sanity check on the trans cooling lines routing.....
front port on trans....to
bottom radiator inlet port....to
internal radiator cooler....to
upper radiator oulet....to
transmission cooler inlet (pass side)....to
transmission cooler outlet (drivers side)....to
rear port on trans
is this correct?
Old Oct 11, 2007 | 06:31 PM
  #1993
ZZebes's Avatar
rear port on trans
is this correct?
appears to be correct yes
Old Oct 11, 2007 | 07:05 PM
  #1994
moregrip's Avatar
what a rush!
cool, you don't sound sure though, lol, are you?
Old Oct 11, 2007 | 07:17 PM
  #1995
moregrip's Avatar
what a rush!
as long as the above routing is correct adding the larger tranny cooler turned out MUCH better than I expected.
Didn't need any aftermarket lines, just 2 inverted flare to -6AN adapters, 2 -6AN tubing nuts/collars, and one 90deg -6AN fitting. Made two bends with a handheld bender (one 25deg inlet side, one 90deg outlet side); next cut off the factory ends; then flared them to 37deg, done, call it good. Turned out super clean and here's what I did:
view from the front:
inlet:
outlet:
side view of hard line routing(clean):
Old Oct 11, 2007 | 08:33 PM
  #1996
leftcoast32's Avatar
FormerVendor
very clean install!!
Old Oct 11, 2007 | 08:57 PM
  #1997
wkdivr's Avatar
Thumbs up
Everything's looking good, Grippy!!! Don't mean to be a dick, but remember this: If you go to the local hose suplier (like Parker Store or any hydraulic supply), they may sell you a -6 fitting, but they usually deal in JIC, not AN stuff. I found out the hard way. JIC wil work on AN stuff, and vice versa, but they will leak. And you'll break a fitting trying to get it tight enough to stop leaking. I'm sure you've already addressed this, but I thought I'd throw it out there, anyway. Best of luck to ya, bro!!!
Old Oct 11, 2007 | 09:18 PM
  #1998
moregrip's Avatar
what a rush!
they are 37deg brother, I'm positive
Old Oct 11, 2007 | 10:27 PM
  #1999
moregrip's Avatar
what a rush!
it was bound to happen sooner or later, what is this and where does it go? LOL!
Old Oct 11, 2007 | 10:50 PM
  #2000
Richard@WCCH's Avatar
FormerVendor
It goes on the back of one of the cylinder heads (driver's side?). I suppose it helps rout the wiring and brake booster hose. The dowell fits into one of the accessorie bolt holes and the bracket is held by the one bolt. I don't belive it has any other purpose and may not be necessary for your build.
Of course it may be a part that is only needed for installation by the factory. I don't think you'll miss it if you leave it off.
Richard
