Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1491
Stripping anodize can be easily done with oven cleaner (sodium hydroxide), make sure you wear gloves and have cold water for rinsing. Of course, when you strip you will lose material. If the bore is coated i would recommend it be masked off from stripping or you might find it a bit loose.
have you considered leaving the hard coat on the ribbed areas and polishing the outer areas?
#1492
#1493
#1494
Originally Posted by Keith
Is that rusty steering box is driving you nuts? A little POR-15 would take care of it.
#1495
Originally Posted by OneBadSSS
POR-15 is the shizz! We use that stuff for our topside preservation work on my ship!!
#1496
Originally Posted by 2005SSR6Speed
#1497
I've been subscribing to this thread for quite awhile now and I say wow, good work, and thanks for all the useful info and pics. However, damn this thing needs an index.
I'm sure it would be a great deal of trouble and I would understand if you didn't want to spend the time but...
What about starting individual threads for each topic. Example, 8-rib conversion thread, Trans install thread, motor thread...............
Hope I don't get flamed for this.
#1498
it was interesting to see how the hard coat came off btw, not exactly a one shot deal
nothing more to report for a while guys
#1500
Good deal. Yeah, the hard coat is a bit more dense and thick than regular anodize. Did you use the "easy-off" method
wasn't very easy off though
