Petro's Project ERL Superdeck 427 w/ Whipple 2.9L
#572
RVP applies to IAT. C16 wouldn’t do as well as Q16 with IATs below 60* for example. With this being fuel injection the fuel is still a liquid when it hits the back of intake valve and as it enters the cylinder. IMO the RVP isn’t transparent once the intake valve warms up. With a carb a good portion of the fuel is still a liquid once it enters the cylinder as well.
#575
I have a gauge for that
To described the combustion chamber as "chaotic" when an engine is running would be an understatement. Saying something will help X % would be nearly impossible to isolate. Things are done on a probabilistic basis as its impossible to do deterministicly with any confidence.
#577
#580
I buffed the counterweights in hopes it would help oil sling off but I don’t think it’ll be a issue since the mains and rod journals are pressure fed oil. Plus the moly coating on the bearings holds more oil since it’s porous. I also looked at them magnified 40x and you can see lots of nicks and gouges still....I’ll try to get a pic of what I’m talking about. They weren’t visible before since the grinding marks tricked the eyes into thinking they were all straight lines but after polishing there’s nasty looking gouges from the abrasives loading up. Pretty cool stuff to see.
