Pearl's rcsb awd turbo build!
Old Feb 8, 2016 | 03:24 PM
  #291
CCrowell2's Avatar
Duramax looks killer with the new wheels.
Old Feb 8, 2016 | 03:45 PM
  #292
mikeyjm1's Avatar
I love black wheel but not the two toned stuff. All black or nothing. So Im digging the new ones.
And I cant stand those obnoxious aftermarket grills. So I'm loving the clean GMC front.
All in all, great looking truck.
Old Feb 8, 2016 | 10:09 PM
  #293
Mortiz's Avatar
Formerly PurplePearl (2014-04-06)
Originally Posted by Atomic
Well thats asking for trouble...might want to get the boost under control or youll be pulling the motor soon if its not already hurt.
Only ran it for a day. Did not beat on it either. I have the tru boost in there that does not work at all and is a crappy setup. Once I have a minute I will get that manual boost controller and dial it down to about 12lbs.
Old Feb 27, 2016 | 12:54 AM
  #294
Mortiz's Avatar
I finally got the truck all dialed in and was running good. Not 2 miles later... Less than few hundred miles on this trans
Old Feb 27, 2016 | 09:57 AM
  #295
1FastBrick's Avatar
Custm2500's Rude Friend
That doesn't look good...
Old Feb 27, 2016 | 10:49 AM
  #296
Mortiz's Avatar
Dumped all the fluid in less that 400 ft.
Old Feb 27, 2016 | 11:09 PM
  #297
Mortiz's Avatar
What would most likely cause a front main blowing like this? Maybe the front pump went out?
Old Feb 27, 2016 | 11:38 PM
  #298
Byrdman11's Avatar
The problem is trans pressure is pushing seal out. I've seen it a lot. You have to remove front pump drill out the return behind the seal. I drill my 4l80 is big as the pump had room for.
Old Feb 27, 2016 | 11:39 PM
  #299
Byrdman11's Avatar
You can use old seal to judge how big hole can be. And I oval the hole behind seal to get most flow.
Old Feb 28, 2016 | 08:31 PM
  #300
Mortiz's Avatar
Got the trans out today. Torque converter wont slide out. Used some force and wouldnt come out. Trans was built by jakes performance.
