Pearl's rcsb awd turbo build!
Old Dec 13, 2014 | 02:07 PM
  #251
Mortiz's Avatar
Formerly PurplePearl (2014-04-06)
Originally Posted by GMCtrk
Sounds like the heads were torqued incorrectly
I think this is the problem. I am gonna pull the other head tonight and see what they are torqued to when I pull them off.
Old Dec 14, 2014 | 09:07 PM
  #252
Mortiz's Avatar
Old Dec 14, 2014 | 09:09 PM
  #253
1FastBrick's Avatar
Custm2500's Rude Friend
Issue resolved???
Old Dec 14, 2014 | 09:15 PM
  #254
Mortiz's Avatar
no that is when i was trying to figure out the problem. i am send out the heads tomorrow to get them checked. but im am certain that they were torqued wrong.
Old Dec 15, 2014 | 10:34 AM
  #255
ShredSled's Avatar
Are you using head studs?
Old Dec 15, 2014 | 03:29 PM
  #256
Mortiz's Avatar
Yea I have ARP Studs.
Old Jan 3, 2015 | 05:45 PM
  #257
Mortiz's Avatar
Ok so I finally got everything done. Pulled the heads and got them pressure tested and surfaced. Found a broken valve spring for who knows why. Put the heads back on and torqued them correctly. Everything seems to be in good order now. I have only put about 10 miles on it because the roads are snowy. Went into boost a couple times and didn't have any weird noises or coolant blowing. Cant wait til it gets warmer out.
Old Jan 3, 2015 | 05:46 PM
  #258
Mortiz's Avatar
Something is messed up with my truboost though. It says I keep going to like 23 lbs of boost. I need to figure that out next. Def not 23lbs
Old Jan 25, 2015 | 08:13 PM
  #259
Mortiz's Avatar
Both videos suck.. I need to get a go pro.. That 0-60 was at about 80-90% throttle. I am still having problems getting the truck dialed in.
Old Jan 25, 2015 | 08:16 PM
  #260
GMCtrk's Avatar
Looks killer.
