OBS 97 Z71 05 5.3 and Radix Swap
Old Feb 12, 2010 | 08:34 AM
  #81
ChevyLee's Avatar
twin terbies
From Leander huh? I am from Round Rock, but spend a lot of time in cedar park. Looks good.
Old Feb 12, 2010 | 06:45 PM
  #82
exodus's Avatar
Originally Posted by turboescalade
yea, I made sure to send all the polished pieces with it. and i'm positive I threw in the support. The pulley is a 6 rib 2.8 I had bought from westers garage where i was getting the truck tuned
Do you recall what box you put the support into? I will look through it all again, but I do not think I have It, and there was no holes on the boxes. I will double check though to be sure tomorrow morning. I do however have the 2 bolts for it. As far as the rails go...That is what was on the setup when I recieved it.
Old Feb 12, 2010 | 06:49 PM
  #83
exodus's Avatar
Originally Posted by james8997
wow, i just spent 20 min reading through this thread. few things,
1st off, thank you for serving for out country, my hat is off to you
now for the questions, the harness you used, was it a plug n play deal?
it looks like your using the black box PCM, will you be switching to the 0411 pcm? the black box pcm has a rev limiter of 5800 RPM, i dont think any tuner has been able to break that.
who is gona tune it?
i also have a 97 Z71, hell same color
how are you gonna get you stock tach to work? thanks
I am going to get an aftermarket tach, but I believe you can get an interface box to get the stock one to work if you like. As far as the pcm goes, I am using the stock one that came with the engine and it's harness. I am not sure which one it is, but I will be ok with the 5,800 rev limit if it is locked in...atleast for now anyway. That is a clean looking truck you have there btw. Thanks for the support too, I apreciate that.
Old Feb 12, 2010 | 06:56 PM
  #84
exodus's Avatar
Ok, so after working a few days we got a 4 day weekend this weekend for the holiday, and I am trying to get it all wrapped up by the end of that.
Today I got the Y pipe installed, and it fits great! It is a stock piece with magnaflow high flow cats.
Then I managed to get the core support cleaned, painted, and installed along with the radiator, fans, double radiator for the heat exchanger, and the trans cooler. I mounted the headlights, and re ran the harness for the lights and plugged in what I could. Finally modified the hood latch bracket, and mounted it and attached the release cable.
Old Feb 12, 2010 | 07:00 PM
  #85
SuperchargedSS's Avatar
are the puller fans still mounted to the intercoolers?
Old Feb 12, 2010 | 07:01 PM
  #86
exodus's Avatar
I need to find the routing for the heat exchanger hoses and pump location. Either turboescalade or moregrip any info on this would be greatly apreciated. Also the wiring that was with this kit...where did it all go?
Old Feb 12, 2010 | 07:02 PM
  #87
exodus's Avatar
Yes they are...just havent ran the wires yet from them.
Old Feb 12, 2010 | 07:09 PM
  #88
moregrip's Avatar
what a rush!
originally (the harness we built), would have taken power from a keyed on source using a 3 relay configuration that would provide constant power to the dual heat exchanger fans and the intercooler pump. Hookup would have been power and ground (easy) with the 2 fans and I/C pump plugging right in.
Old Feb 12, 2010 | 07:14 PM
  #89
exodus's Avatar
What I have sounds like that...there are 3 relays, but I will have to take some pics to show it to you, and then maybe you can advise me better on this? What about the hoses? Intercooler to tank, tank to blower, and pump? Pump location in this system?
Old Feb 12, 2010 | 07:30 PM
  #90
moregrip's Avatar
what a rush!
hoses will need to exit on the passenger side, any 5/8" heater hose will work (just don't get the red stuff please), I had the I/C pump mounted directly below the Canton tank (not sure if you have the room/your call there).
upper barb is entry point, lower barb is exit point to I/C pump, and drain valve
