OBS 97 Z71 05 5.3 and Radix Swap
#71
wow, welcome back and congrats on the build!
Couple of things:
1. Where is the blower snout support?
2. Why is the drivers side fuel rail not polished?
3. good call pinning the crank!
4. what size pulley is on the blower and what type is it for that matter?
5. Keep going brother! I bet your having a great time!
Couple of things:
#74
Couple of things:
Couple of things:
#76
that kit should have a polished blower snout support that is specific to that setup because of the spacer used on the blower head unit and was secured with SS ARP 12pt bolts.
Double check your parts and/or try to find out where it is because an off the shelf snout support won't work. It should have been included in the kit.
#77
#79
wow, i just spent 20 min reading through this thread. few things,
1st off, thank you for serving for out country, my hat is off to you
now for the questions, the harness you used, was it a plug n play deal?
it looks like your using the black box PCM, will you be switching to the 0411 pcm? the black box pcm has a rev limiter of 5800 RPM, i dont think any tuner has been able to break that.
who is gona tune it?
i also have a 97 Z71, hell same color
how are you gonna get you stock tach to work? thanks
#80
yea, I made sure to send all the polished pieces with it. and i'm positive I threw in the support. The pulley is a 6 rib 2.8 I had bought from westers garage where i was getting the truck tuned
