OBS 97 Z71 05 5.3 and Radix Swap
Old Feb 10, 2010 | 08:48 PM
  #71
moregrip's Avatar
what a rush!
wow, welcome back and congrats on the build!
Couple of things:
1. Where is the blower snout support?
2. Why is the drivers side fuel rail not polished?
3. good call pinning the crank!
4. what size pulley is on the blower and what type is it for that matter?
5. Keep going brother! I bet your having a great time!
Old Feb 11, 2010 | 03:47 AM
  #72
AndysC3's Avatar
What are the advantages of the 122 over the 112?
Awesome build.
Old Feb 11, 2010 | 06:55 AM
  #73
exodus's Avatar
They look like good quality pieces....shame the wont fit my 4WD, I would love to use them.
Old Feb 11, 2010 | 06:59 AM
  #74
exodus's Avatar
Couple of things:
I am going through all of the things in the kit that I was sent, and can't find the snout support so I will have to get one. Everything that Is there is how it was when I got the kit so I have no idea on the fuel rail. I believe that Is the 2.8 pulley, but I plan on running a little larger one. Going to wait and see what she pulls first. Thanks alot man, I hope you like it...I have worked my *** off thus far, and will be doing a lot more friday thru mon. Should have it to the tuner by mon if all goes well.
Old Feb 11, 2010 | 07:01 AM
  #75
exodus's Avatar
Awesome build.
The 122HH is a little larger than the 112, and has a little bit more twist on the rotors inside.
Old Feb 11, 2010 | 04:55 PM
  #76
moregrip's Avatar
what a rush!
that kit should have a polished blower snout support that is specific to that setup because of the spacer used on the blower head unit and was secured with SS ARP 12pt bolts.
Double check your parts and/or try to find out where it is because an off the shelf snout support won't work. It should have been included in the kit.
Old Feb 11, 2010 | 09:28 PM
  #77
SuperchargedSS's Avatar
yeap. t'was that way when I received it from grip and when I sold it to the other owner. Dunno where the other polished rail is or the snout support. Interesting....
Old Feb 11, 2010 | 10:21 PM
  #78
GMCtrk's Avatar
Looks great, but those turd colored manifolds ruin the aesthetics! I would grab a set of OBX shorties on ebay for cheap, they'll bolt right up to the stock Y pipe.
Old Feb 12, 2010 | 12:53 AM
  #79
james8997's Avatar
wow, i just spent 20 min reading through this thread. few things,
1st off, thank you for serving for out country, my hat is off to you
now for the questions, the harness you used, was it a plug n play deal?
it looks like your using the black box PCM, will you be switching to the 0411 pcm? the black box pcm has a rev limiter of 5800 RPM, i dont think any tuner has been able to break that.
who is gona tune it?
i also have a 97 Z71, hell same color
how are you gonna get you stock tach to work? thanks
Old Feb 12, 2010 | 07:12 AM
  #80
turboescalade's Avatar
yea, I made sure to send all the polished pieces with it. and i'm positive I threw in the support. The pulley is a 6 rib 2.8 I had bought from westers garage where i was getting the truck tuned
