Oakley's History Lesson and Build Thread
Old Mar 11, 2014 | 04:34 PM
  #491
silverado.408's Avatar
Are you setup for return ? Or return less.
Old Mar 11, 2014 | 04:42 PM
  #492
oakley6575's Avatar
It will be a return system. -10 feed and -6 return
Old Mar 11, 2014 | 05:18 PM
  #493
BlackGMC's Avatar
Resident Retard
if you would have mounted the bulkhead fitting on the flat portion and not on the vent you would have been ok.
Plenty of room guys
Old Mar 11, 2014 | 05:41 PM
  #494
Atomic's Avatar
I have a gauge for that
Mine was close with a -8 on top of the hat...I beat the hell out of the bottom of the bed with a sledge anyway, just to be sure
#worktruckforlife
Old Mar 11, 2014 | 05:44 PM
  #495
oakley6575's Avatar
Yea I agree. I just wanted the bulkhead as high as possible because I think the barb fittings will sit too low in the bucket and too close to the pumps. I bought this bucket assembly just for R&D for $25. So if its not going to work, no biggie. But I'd like to get a tank and test fit it with a 90* bulkhead.
Old Mar 11, 2014 | 05:47 PM
  #496
oakley6575's Avatar
#worktruckforlife
I'll move it down to the bottom and see where that puts me. It will still stick above the evap extrusion like 2"
Old Mar 11, 2014 | 05:49 PM
  #497
BlackGMC's Avatar
Resident Retard
Here is mine. Notice the check valve on the feed. I used a 90* fitting instead of a hose end.
Bottom view
Top
Old Mar 11, 2014 | 06:09 PM
  #498
Atomic's Avatar
Well since we are sharing pictures...
Old Mar 11, 2014 | 06:22 PM
  #499
BlackGMC's Avatar
Resident Retard
I like your Y fitting! I wish i would have saw that back when i was doing mine.. I like your setup alot better than mine.
Old Mar 11, 2014 | 06:33 PM
  #500
oakley6575's Avatar
Who's Y are you referring to? I like how you cut the stock feed tube off. Maybe I will copy you
