Oakley's History Lesson and Build Thread
Old Oct 7, 2013 | 09:27 PM
  #151
ak2007r6's Avatar
^^ That manifold looks beautiful. Can't wait to see it all installed
Old Oct 7, 2013 | 09:35 PM
  #152
oakley6575's Avatar
Good luck and get to work!
Just started working two jobs... FML
Before, I had nothing but time to mess with this truck now I don't know how I will find time Tonight I pulled the headers and crossmember out to get ready for the tapped oil pan. I was only at the shop for a couple hours and I had to put together some 706 5.3L heads for my grandpas customer in Norway. Anyways, I'll post pics of any progress that gets done this week.
Old Oct 12, 2013 | 04:43 PM
  #153
oakley6575's Avatar
Got a chance to work on the truck today. I got the hot pipes wrapped and I sorted through all my parts. Should be a pretty fast install once I mount the intercooler. Any idea what thread size an IAT sensor is?
Old Oct 12, 2013 | 05:14 PM
  #154
Chevy_King1500's Avatar
looking good! install is fairly easy, only took me a weekend to complete
Old Oct 12, 2013 | 05:25 PM
  #155
Choda's Avatar
Nice wrap! I hated those bands, they didn't work for crap for me and I ended up using hose clamps
I also installed mine in a weekend
Old Oct 12, 2013 | 06:12 PM
  #156
oakley6575's Avatar
I wish I had a weekend I could dedicate to getting it done. I really want to drive it. I've only been able to work on it for a couple hours at a time.
The bands are ****. How are you supposed to get them tight? Is there a tool you can use on them or something?
Old Oct 12, 2013 | 06:18 PM
  #157
oakley6575's Avatar
After wrapping the hot pipes, I didn't have enough to do the drivers side manifold. So I just painted it and bolted it up. I used the fiberglass spark plug wire sleeves but I'm sure it won't hold up. I will probably take the manifold off and wrap it after I drive the truck for a while. So the drivers side is complete
I was going to bolt up the log but decided to wait until I reroute my heater hose. I'm thinking about using two 90* hose barbs up by the firewall and routing the hose under the coolant reservoir. Should look pretty clean that way. Or should I just use the 90* barbs by the water pump and route the hoses in between the passenger valve cover and intake manifold to the firewall? Any suggestions or recommendations?
Old Oct 12, 2013 | 08:20 PM
  #158
I didn't use any 90's...looped them between the fender and coolant tank. I wouldnt worry about the drivers manifold either. Arms itching??
Old Oct 12, 2013 | 08:28 PM
  #159
BlackGMC's Avatar
Resident Retard
I rerouted mine to go under the coolant tank but i am using a different coolant tank.
Old Oct 12, 2013 | 09:03 PM
  #160
oakley6575's Avatar
Do you two have any pics of how you routed the hose back into the water pump area under the turbo?
