Not a truck, not a LS engine, but weighs as much as a truck, "69 Twin TurboCharger"
Old Mar 24, 2012 | 05:12 PM
  #111
JoeyGC5's Avatar
Envious of your progress so far
Old Mar 24, 2012 | 05:13 PM
  #112
AKlowriderZ71's Avatar
11 Second Hall Moniter
Nice to see you're back to working on the project!
Old Mar 25, 2012 | 12:14 AM
  #113
1989k1500's Avatar
Looking good!
Little finish work and that PS bracket will look just fine.
Putting the quick change in the car huh? Doing IRS?
Old Mar 27, 2012 | 07:29 PM
  #114
Wilde Racing's Avatar
How do I change this text
Thanks,
no IRS, I haven't made up my mind on what type of rear suspension the car will have. At this point I just like to get it going and make the decision later....
Old Apr 30, 2012 | 05:46 AM
  #115
Spoolin's Avatar
GFYS and STFU
Projects looking good! Any updates?
And thanks for your help btw, hope to see you later this week.
Old May 1, 2012 | 07:52 PM
  #116
Thanks, Not much. Too busy with other JUNK
I have started the mock up on the drives side, changed the master cylinder mount a bit.
I just got a TIG welder so now I want to start over.....
Old May 2, 2012 | 03:40 PM
  #117
thestriker's Avatar
dammmmm bro nice build
Old Jul 10, 2012 | 07:21 AM
  #118
Thank you,
Getting a little more time to work on it lately. I got the drivers side down pipe tacked, I just need to finish the waste gate pipes, mark all the locations for the egt and wide band ports, pull the exhaust and finish welding it up! Then I can finial move on to something else.
Im so exhausted of work on the exhaust, I have spent a little time mounting the seats. All that is left is to finish the shifter mount.
Old Jul 10, 2012 | 07:53 AM
  #119
TIM Z's Avatar
11 sec. Truck Mod
Those seats are cool, look good in there. Like the shifter too.
Old Jul 17, 2012 | 09:47 PM
  #120
Thanks..
Well here is the after work weekend update. I got a lot done, but still SO much more......
Passenger side down pipe and waste gate down pipe welded... Be gentle on the weld quality judgment I'm just learning to TIG weld.
Passenger side shot showing custom valve cover weld... (Weld done by a pro TIG welder Stoichiometric)
Drivers side turbo support and alternator bracket.
EGT ports welded in the drivers manifold..
drivers side assembled on bench..
