NNBS GMT900 - DOD delete - cam swap -
Old Oct 30, 2010 | 11:32 AM
Tootall's Avatar
Default NNBS GMT900 - DOD delete - cam swap -
Here's today's project.
55k miles on the clock
- Owner supplied parts -
Comp 918s
Custom Comp cam
GM head bolts
LS7 lifters
LS7 Valley cover
7.4 push rods
lifter trays
5.3 - 5.7 GM MLS head gaskets
the truck already has a drop, Pacesetters, & an ASP under drive pulley.
Open header vid later on today . . . . .
Old Oct 30, 2010 | 12:07 PM
custm2500's Avatar
Ph.D. in HUBRIS
Nice what cam is that? Makes me want to brake the bank get lifters, and other suporting parts) and drop in my cam!
Old Oct 30, 2010 | 01:41 PM
CJ Hungus's Avatar
How much to ship Tootall to MN?
Old Oct 30, 2010 | 03:02 PM
Tootall's Avatar
little bad discovery when the front cover was removed . . . . lots of extra work now.
Stock timing chain dampener BROKE ! . . . plastic and the spring plate, timing chain has lots of slack.
Dropping the oil pan, pulling the pump, swapping out the timing chain, timing chain dampener. . . .
I'm fighting the oil pan, taking a break to post these.
Old Oct 30, 2010 | 03:20 PM
skipperdaddy's Avatar
Yep, put the ls2 dampener when i did my dod delete/cam swap... heard about too many of those breaking...
Old Oct 30, 2010 | 04:16 PM
smokeshow's Avatar
Mod with training wheels
Same here...
Old Oct 30, 2010 | 04:50 PM
fortplainman's Avatar
cool in for the build. might be what i do over the summer.
Old Nov 1, 2010 | 09:05 AM
double047's Avatar
14 Second Truck Club
Nice job, keep the updates coming.
Old Nov 1, 2010 | 11:06 AM
smokeshow's Avatar
Any reason you stuck with the stock tty bolts instead of going to some ARPs?
Old Nov 1, 2010 | 02:30 PM
Tootall's Avatar
I had "heard/read" about them breaking, but this was the first that I've seen
plan on having a day to knock it out if it's your first time
thanks
for the head bolts? . . . stock heads, no boost, no N02 . . .
