New Build! RCSB Z71 bone stock to 4L80e / Trick 76mm
Old Feb 28, 2015 | 07:48 AM
Beatdown Z's Avatar
Laid Back
Being a 2005, it should have MLS gaskets. You might be surprised how far they'll get you with the stock headbolts.
Old Feb 28, 2015 | 07:52 AM
Beatdown Z's Avatar
Laid Back
Tick Performance Turbo Stage 1 V2 Camshaft for LS1 & LS6 Engines
227/227 | .62x"/.59x" | LSA114+5
Is this the cam you bought?
Old Feb 28, 2015 | 09:50 AM
lxcoupe's Avatar
Originally Posted by GMCtrk
For that power level keep the stock head bolts, they're actually stronger than the china junk
I would if the heads weren't coming off but since they are for the cam, it makes sense to do studs and LS9's. This thread may have convinced me to return the china studs and get ARPs.
Beatdown, truck has 140k on it. I should see 10-12psi and make 550-650 rwhp in that range. Lol maybe I do plan on making a tad more than 550. I think it's good insurance to gap the rings, no? It comes highly recommended on these stock shortblocks but then again this is my first turbo build.
The cam I got from Martin is this one: Stage 1 5.3 turbo camshaft which is 215/219 .612/.585 114+3.
I forgot to mention, last week I also pre-emptively raised the bed and installed the Walbro F90000267 450lph pump into the stock bucket. Went in real straight forward and no codes or anything, quiet too. I hadn't seen any pics or vids of guys raising the bed this way, but I put 2 2x4's under the bed frame on each side above the tires (rear end lowered on jack stands in the lift bay and wheels removed) and I used the lift arms to effortlessly raise the bed. Couldn't have been easier. I started with the intentions of using the tilt bed method because I couldn't envision a way to use the lift. Kicking myself for not getting a pics.
Old Mar 1, 2015 | 09:35 AM
HIPSI's Avatar
I've got close to the same setup as you. Still on stock headbolts and gaskets at 15 lbs, your truck should do well.
Old Mar 1, 2015 | 09:36 AM
Where did you get this info? Personal experience??
Old Mar 1, 2015 | 10:06 AM
zaathur151's Avatar
I also think messing with rings is a waste of money and time at 140k that's low miles for a LS engine that has been maintenance well in my opinion that motor would handle your power levels just fine even with stock head bolts but I always recommend ARP bolts or there studs for room for more boost later on, boost can get addicting
Old Mar 1, 2015 | 10:36 AM
Goat's ss's Avatar
Yea plan on starting my parts gathering this winter for my truck kinda interested in seeing your outcome with this one. Im having a hard time of deciding to go blower or turbo.
Old Mar 1, 2015 | 11:27 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Proper ring gap is important. Just because many people get away without checking/adjusting ring gap, does not mean you will automatically get lucky also.
Old Mar 1, 2015 | 09:51 PM
GMCtrk's Avatar
All 3 (stock, ARP, and china) were tested....search on LS1t.
You got the china in your motor?
Old Mar 1, 2015 | 09:52 PM
GMCtrk's Avatar
Good fuel is the most important thing in making a stock motor live
