New Build! RCSB Z71 bone stock to 4L80e / Trick 76mm
#151
Truck runs on 100% e85 and afr are normally rock solid 11.5:1, I've read a couple posts where Trick says the entry intercooler is good for 10-12psi on a stock 5.3. I'm trying to do 15psi on a 10.5:1 5.3 with a small cam so I'm really curious about an intercooler swap. I also made low peak power at 5200rpm on the dyno and made identical power at 12.x psi and at 15psi.
Rich, how did you measure pressure drop across your intercooler?
#153
I put a pressure gauge on the turbo before the intercooler and compared that to my boost gauge that was reading from the intake. 2-3psi drop is ok, but more than that you probably need a better flowing intercooler. It helps to also relate it to RPM.
#154
Originally Posted by 06 4.8
Our times are VERY close including 1/8 mph and 1/4 so I'm gonna say it probably isn't losing the power. I think it's just hard for these bricks to push through the air once we get faster and faster
Rich, I've already drilled and tapped my compressor housing for 1/8" npt so I can add a sending unit there and add a pid.
#156
Originally Posted by Atomic
Yea if you have the pro input or want to pipe it in through another port. I did it the lazy way and video taped the two pressure gauges and tach
#157
Put the pre ic in the tubing if possible.
Heck take the tubing off the ic.
Hook up a shop vac. The tanks are thick enough to drill and tap 1/8 npt.
You could do both sides.
Just put the vacuum on the side your tapping. It will suck out all the shavings.
Get a couple of vacuum psi gauge a d compare right at the ic.
3" race it's twice as big as that intercooler.
5" race is the one birdman11 is using. Over 1100 hp.
#159
Great build man! Thanks for documenting your build so well, I'll be doing a 2wd rcsb turbo/80e swap this summer and this should help alot. Good to see you're closing in on your goal, 11.7 in a truck is pretty awesome
#160
Below is a stock LQ4 IAT vs spark table:
