My turbo build..
Old Dec 3, 2011 | 04:34 PM
Jake99's Avatar
Default My turbo build..
Well I figered I post up what iv been working on, sold my ls1 and dropped in a 4.8 I got for free, It had a decent amount of miles on it so I went throw it and put new bearing and rings in it along with arp head studs and rod bolts. Im using the stock heads and a 212-212 562 lift 112lsa +5 cam, custom spec'd 3600-3700 stall and 3.73 gears. Heres a few pics of what iv done so far, the cold side piping aint done yet it needs some trimming and adjusting yet I just throw it together to make pics, down pipe dont look the greatest eaither but it will flow fine and it will all get heat wrapped yet..
Old Dec 3, 2011 | 04:35 PM
Jake99's Avatar
Old Dec 3, 2011 | 04:41 PM
SLOXCAB's Avatar
Looks good man!! What size turbo is that?
Old Dec 3, 2011 | 05:08 PM
sharpshooter's Avatar
Nice work man. Do you have any more pics of the hot side crossover pipe installed?
Old Dec 3, 2011 | 05:57 PM
Jake99's Avatar
this is the only one I got, didnt have my zoom lenze so I coundnt get out far enuf to get it all.
http://i832.photobucket.com/albums/z...s/IMAG0353.jpg
Old Dec 3, 2011 | 05:58 PM
Jake99's Avatar
Turbo is a magnum 76mm 96ar bb p trim.
Old Dec 3, 2011 | 06:54 PM
Beatdown Z's Avatar
Laid Back
Nice turbo choice. This thing is gonna be nasty!
Old Dec 3, 2011 | 10:57 PM
Jake99's Avatar
I hope so, im a little short on coin to finish out the fuel system but it should be on there by race season next year, I want to do twin 255s, 8an fuel line and 80# injectors.
Old Dec 3, 2011 | 11:07 PM
smokeshow's Avatar
Mod with training wheels
I can't exactly speak for water cooled turbos because I've never used one, but the rubber hose on that barb fitting might get a little angry with all the heat coming off that thing... I used some rubber hose at first and it leaked a little bit because of the heat-hardened rubber hose. Spaced the hose away from the center section with some fittings, but it still hardened the rubber a bit.
Old Dec 4, 2011 | 01:28 AM
LS1FREEK's Avatar
13 Second Truck Club
We actually used a passenger side F-body manifold flipped upside down for the passenger side and a regular truck manifold on the driver side, it actually worked pretty good. There was more clearence with the F-body manifold.
