My rebuild thread
Old Jun 1, 2008 | 11:47 PM
  #21
thunder550's Avatar
High on diesel fumes
Umm...I'd like my truck to be running sometime before 2010
If I could get my truck up high in the air and get a pressure washer on it I'd clean it up, but I don't think that's likely.
Old Jun 2, 2008 | 12:08 AM
  #22
2005 Silverado's Avatar
SPAM HUNTER
haha time for a 2 post lift Chris, or you could just jack the front up really really high at a car wash and just degrease and pressure wash the bottom, thats what did at lexus. Quick off topic note, Chris it was 5 degree hotter there then there, i moved to a worse place!
Dustin
Old Jun 2, 2008 | 12:59 AM
  #23
350SS's Avatar
looking forward to following your progress...btw what fittings are you using for the an lines that go into the tranny?
Old Jun 2, 2008 | 02:12 AM
  #24
thunder550's Avatar
Originally Posted by thunder550
Reinstalled the trans yesterday and converted the cooler lines to all AN to get rid of the clusterf**k of splices between AN and hard line I had in there before. The old hard lines also rubbed my idler arm when turning. This should be much better.
1/4" pipe to -6AN fittings in the trans, 90* -6AN to hose barb, -6 pushlock hose
Gotcha covered in the original post
Old Jun 2, 2008 | 02:15 AM
  #25
CHEVRACER83's Avatar
glad your up and running with this thing... hopefully your engine will be done and on its way back efore you know it, and the beast will live again soon...
good luck brother
Old Jun 2, 2008 | 02:23 AM
  #26
thunder550's Avatar
good luck brother
Thanks
I'm going to be out of town from June 10-22, so there will be about a 2 week hold on things while I'm gone. Hopefully everything I need will be here after that so I can hit the ground running when I get back.
Old Jun 2, 2008 | 02:30 AM
  #27
Spoolin's Avatar
GFYS and STFU
I don't think enough people told you so... "You have the filter backwards".
I like this one thread idea...makes it easier to follow along what's going on!
Looks good, keep up the nasty work. btw I didn't know that you were black!
Old Jun 2, 2008 | 07:55 AM
  #28
SPAM HUNTER
Sig looks good too chris!
Dustin
Old Jun 2, 2008 | 09:17 AM
  #29
350SS's Avatar
Sorry should have been more specific in what I was asking. You're running a 4L80, correct? Didn't one of your original trans fittings look like this:
Old Jun 2, 2008 | 10:09 AM
  #30
thunder550's Avatar
No, I have the older style 4L80E that doesn't have the long fitting like that. I think that's exclusive to the newer style 4L80E.
