My lifted 00 silverado Lq9 swap and turbo build
#51
Well I just had the factory setup tell I did some research I guess the new question is what is the best way to setup a catch can and I don't know if this matters but the driver side valve cover has a internal pcv valve in the valve cover that seas is not serviceable is that ok to leave or do i need to buy a new valve cover without one?
#52
#54
Lol I had the same oil smell and eventually they make a mess of your engine bay. I went with the monster can with the dual check valves. I like it because it keeps the crankcase in a vacuum like factory, in and out of boost. Zero smell and I just drain it about every 500 miles.
#58
Alright here Is my problem Im over boosting I have a 6psi red spring in my precision wastegate that came with the kit and its spiking up to 13psi there is straight vacuum to the side port of the wastegate and the top port goes to my AEM boost controller even with the controller off it still overboost any ides?
#59
Where did you put your wastegate, down on the crossover under the truck between the banks, or is it near the turbo after passenger side log?
#60
It's right on the manifold about 3" from the turbo on there trick turbo manifold I even removed the top vacuum line that goes to boost controller and just used spring pressure still no luck
