My large frame front mount project with two videos
Old Feb 10, 2009 | 04:41 PM
  #91
quicksilverado's Avatar
Originally Posted by Wilde Racing
We shall see, I can always go to a 1.10 but I'd have to go with a smaller exhaust wheel. I hope it is not too bad, that is the reason for the split exhaust, to try and help with spool, but to be honest I can handle a great deal of lag..... Plus I think A LOT can be done in the tuning...
What sized exhaust do you have?
Cablebandit has the same turbo with a 408. It was so bad with the 408 he swapped down to the 1.10. He could not brake the tires loose with the 1.32. At the track it took forever to build boost with a 2-step and transbrake.
Old Feb 10, 2009 | 04:53 PM
  #92
vanillagorilla's Avatar
What size turbine wheel does it have?
Old Feb 10, 2009 | 05:08 PM
  #93
explorer5.0's Avatar
TOTM: November '07
Here is an iron headed 9.1:1 355 with a 75mm S400 with 1.32 housing....
Flyinhillbilly's+Dyno+Run.+639+rwhp+%40+18.6+PSI
Old Feb 10, 2009 | 05:10 PM
  #94
TOTM: November '07
It is 88mm I believe
Old Feb 10, 2009 | 05:50 PM
  #95
ZZebes's Avatar
Best use of a magnetic tray right?
Sweet jesus
Old Feb 10, 2009 | 05:56 PM
  #96
Wilde Racing's Avatar
How do I change this text
the 1.32 has a 96 turbine, the 1.10 has a 83 turbine. I was told the 83 would be too smal for my hp goal, so I went with the 1.32/96 wheel.
Thanks for the video, that does have some lag, I wander how much they loaded the dyno??????
Old Feb 10, 2009 | 07:30 PM
  #97
joehawkz71's Avatar
just go with it! if you dont like it you can always change it.. and you wont know if you like it unless you try it.... so i say go for it! plus. lag is fine..its just foreplay.. lol and who doesn't like a little foreplay!
Old Feb 10, 2009 | 08:07 PM
  #98
I don't plan on changing anything.... I've learned one thing, what some call excessive lag, other call normal... lol and my .96 was way to small in the rear...
Old Feb 10, 2009 | 08:46 PM
  #99
blue2003ls's Avatar
No matter what happens I'm hooked... Every time I see this thread there seems to be progress. Good job Dusty. Can't wait to see the results on the track.
Old Feb 10, 2009 | 09:04 PM
  #100
trever1t's Avatar
2nd fastest 5.3 ECSB
what's a little lag between friends?
