My Iron LS2 - Patriot 243s, EPS Cam, 3.5" catback, misc crap buildup
Old Jun 20, 2011 | 09:30 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by 2007chevy5.3l
Put some gas on it. Youll make the torque you want and probably see 11s lol
Naw, Nitrous is kinda like credit, nice when you have but sucks when you run out....
Old Jun 20, 2011 | 10:30 AM
2007chevy5.3l's Avatar
True true. But how often do you race your truck? A 10# bottle would last you months.
Old Jun 20, 2011 | 10:47 AM
BlackGMC's Avatar
Resident Retard
Well when i had people to goto the track i use to race all the time, but look what happened to most of the guys in DFW and our local K-dale track turned into a retarded version of the movie "Biker Boyz".......
Old Jun 20, 2011 | 10:59 AM
Well the last time I went to K dale the racing sucked. So i wont be going back. Northstar is nice but its in denton and dallas raceway is an hour away. So i imagine that track days will be rare
Old Jun 20, 2011 | 12:06 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a nice combo for sure Corey...about the LS7 lifters, there was a thread on here a while back with pics showing that the cup on the LS7 lifter is taller than the original LS lifters, so if anything, it would require a shorter pushrod (not taking the cam base circle into account). But, as mentioned, they are the "new" stock replacement and have some room to play for preload range. There's a lifter preload thread in the sticky section of the Internal Engine Mod section that has some good info that you may like
Old Jun 20, 2011 | 12:21 PM
Phantom's Avatar
11 Second Club
https://ls1tech.com/forums/generatio...1-lifters.html
Old Jun 20, 2011 | 05:40 PM
f4tal's Avatar
The actual LS7 lifters are the same length as the stock lifters.
HOWEVER, the seats on the LS7 are slightly taller so shorter PR's will be needed. Some guys luck out and run the 7.4's but since those heads are different idk for sure what size you'll need.
Old Jun 20, 2011 | 05:42 PM
Phantom's Avatar
11 Second Club
^^^incorrect information...read the link posted above
Old Jun 20, 2011 | 05:52 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I'm using 7.375 pushrods with my gt2-3 and ls7 lifters with stock heads and head gaskets thickness and they're are correct as checked with a pr length tool and running .06 preload...
Old Jun 20, 2011 | 06:13 PM
bigboy576103's Avatar
But the BEER was good
My motor has .050 play under the rockers, Alexes had bout .060-.100 under his ..
its tight but at idle and low cruise its still got plunge and under a load it kinda turns into a solid roller Cheap trick i was taught by my head guy......
my setup is ls7 lifters,stock gaskets, heads decked .030, 7.4 pr's
