My first engine build.
Old Jan 23, 2018 | 03:36 PM
  #31
Petraszewsky's Avatar
For what it’s worth I just coated a set of Autotec pistons for a guy and while they are really nice pistons they defintely needed a detail. Where they had machines the hard edges burrs were left from the tooling that you could cut a fingernail on. The oil drainback holes had burrs in groove etc etc. Just a FYI
Old Jan 24, 2018 | 05:02 PM
  #32
crashmymax's Avatar
Set the engine in place today. Waiting on parts so had nothing else to do. I like the alternator down low but it's close to the steering shaft.
Old Jan 24, 2018 | 08:27 PM
  #33
crashmymax's Avatar
Put my overflow tank inside the passenger fender.
Old Jan 26, 2018 | 04:35 PM
  #34
crashmymax's Avatar
mocking up a place for my battery. Have enough room for more stuff if I need.
Putting it where the spare used to be.
Old Jan 27, 2018 | 09:49 AM
  #35
crashmymax's Avatar
Not enough room for surge tank to work where I mounted it. Ordered more fittings will have to wait until next week to finish the fuel system. I did get the stock sending unit modified. Regulator and filter removed. New fittings on top. The corrugated fuel line is nice stuff to work with.
Old Jan 27, 2018 | 12:51 PM
  #36
crashmymax's Avatar
I am thinking of moving the fuse box and computer out of the engine bay. I am not removing any circuits the truck is still my daily. It looks awesome and that's why I want to do it.
I think the easiest way would be to put it behind the front bumper but also considering putting it next to my battery in the spare tire location. I figure gm has kept most the same colors and wire gauge size over the past years. So I might see if I can get big chunks of harness from u pull it. They wont have anything newer then late 90's early 00's but hoping I can keep all the colors the same.
if you have any tips or ideas please share them. I am 50/50 on doing this because the amount of work it will be but it will look awesome.
Old Jan 30, 2018 | 10:59 AM
  #37
crashmymax's Avatar
Man I made a mess.
Old Jan 30, 2018 | 11:47 PM
  #38
03chevytruck's Avatar
Nice build. Do you remember how much the pistons were? I'm trying to find a budget minded piston to use on stock rods to compare to the price of forged rods/pistons. Also what is the best way to contact stock48?
Old Jan 30, 2018 | 11:56 PM
  #39
crashmymax's Avatar
Honestly can't remember how much they were. It's been awhile. Send him a PM. He will respond.
Old Feb 2, 2018 | 10:34 PM
  #40
crashmymax's Avatar
had a busy week so not much time for the truck. I did a little bit of work on the fuel system.
