My first engine build.
I have in my life only done 2 comlplete rebuilds both 4 bangers. 1 successful and the other not so much. Both times I had my dad nearby to help not this time. Anyway found a guy here in rapid city that takes his race stuff to denver for machine work. No local guys are interested in helping me.
I have my original 5.3 (LC9 I believe) out of my 09. Has about 60,000 miles on it. The plan is to bore it out to 3.898 and have a 5.7. My truck is turbo charged so this is FI build. Nothing special I know its been done before just need some advice along the way to make sure I dont screw somthing major up. Budget unknown just going to start and go from there. Hp goals dont know but want to make sure if I decide to go for 800 the engine can handle it but most likley 500rwh. I know i can make that on my stock 5.3 but this will be my backup if i blow it. Things to do and parts to buy. Will add to the list as needed. Machine work bore to 3.898 cost unknown Cam triple 12 most likley (suggestions welcome) cost $399 + shipping Forged pistons ( not sure wich ones to keep compression correct for FI) cost guessing $650 Rods stock unless anyone suggest otherwise. Free Crank stock. Free Valve train no idea what needs done. Just duel springs. Suggestions Timing chain upgrade. I think I have read most guys do this will research. Oil pump upgrade if available. Plug something for better oil pressure. Read that somewhere as well. Heads stock 243. Will have shop go over them. Guessing valves need replaced since 2 of them have damage from piston melting unless they can be cleand up. DOD/AFM Delete $225 Head studs china maybe they seem to be working for other guys. Stall converter $995 Lots of other stuff i am sure like I said this is basicly my first time doing somthing like this. Should hear back in a couple days from machine shop to see if they are willing to do the work and cost. Post your suggestions and thoughts half the fun is planning and discussing this stuff. |
What is your budget?
Knowing how much HP you want to put down will help. What converter are you running? |
If you swap the cam to a triple 12, the DoD/AFM has to go. You'll need a new valley plate, lifters, lifter trays, cam gear.
Originally Posted by wretched73
(Post 5394719)
Originally Posted by FFDP
(Post 5394721)
DOD/AFM delete will be added. |
What is a good stall for daily driver that occasionally tows camper and utv?
Ordered some parts today finally. Got a triple 12 cam and some pistons coming from stock48. Have not decided if ill stay with stock rods or not. Also need to pick up a micrometer and dial bore gauge any suggestions on brands? I see the prices very considerably.
Originally Posted by crashmymax
(Post 5396639)
Originally Posted by Feed
(Post 5396655)
Depends on how much you want to spend... mitutoyo, starrett, brown and Sharpe at the upper end are all good. On the cheaper side, SPI is usually decent for $.
Parts I have ordered now
custom forged pistons and rings 9.5:1 stock48 triple 12 cam stock48 pac single springs stock48 DOD delete kit. texas speed clevite bearings texas speed What else might I need for rebuilding the short block? Is stock oil and water pump ok or should they be upgraded? Would like to have everything I need ready to go before I start. |
I'd say stock oil pulp and water pump are fine.
China studs are good Looks like you have a good list. I would only add new motor mounts. I didn't replace them w mine with 100k miles. |
